Rear Tire Wobble
My rear wheel wobbles subtly to the left and right, causing the tire to rub against the frame of the bike. I've got a couple of pictures here of the tire resting against the frame, and then me placing my finger in between them, to illustrate the wobble. Any advice?
Thanks so much!
Ford
Oops! Sorry for the double-thread, and here are the pictures. Thanks again!
[attachment=106]
[attachment=107]
Hi Fjord,<br />
Lemme take a shot at this(bear with me lol). First when you say &quot;wobble&quot; do you mean when the wheel is in motion? First try to move the wheel (wiggle) side to side with you hand to see if theres any movement that way. Next if you are talking about when the wheel is in motion then the wheel needs to be trued heres Alex's video on wheel truing:
http://bikeride.com/wheel-truing/
For faint of heart, lol, if anyone else would like to add please do so.
Well, the wheel has lateral play at any time. In the pictures I took here, the bike was resting upside-down, and the tire can be moved left and right. The gears move right along with the tire, so everything between the &quot;fork&quot; frame around the back tire is free to move at any time. Thanks for your help Bill - I would be lost on my own.
- the hub needs to be checked and adjusted http://bikeride.com/overhaul-wheel-bearings/ though it is probably shot<br />
- or maybe the wheel is not fixed in the frame
Have you checked the bolts are tight on the wheel? Lol if there's actual play in the wheel and your.able to move it.from side to side then it might be an issue with your axle, which you could replace easily.however if it only wobbles in motion like mentioned above,then it possibly needs trying or dishing!
3,127
12-21-2019, 09:55 PM
10,550
03-23-2015, 06:31 AM
Last Post: eastman
8,370
05-20-2014, 02:49 PM
Last Post: cny-man
7,829
10-26-2013, 08:22 AM
Last Post: 1FJEF
19,305
09-04-2013, 10:27 PM
Last Post: jo3yp
7,583
05-24-2013, 03:17 PM
Philodo H8
Today 12:50 PM
Opinions on Bergamont bikes?
Today 11:58 AM
Today 06:44 AM
Today 06:36 AM
interpreting serial numbers
Yesterday 01:55 PM
05-17-2024 11:50 AM
05-17-2024 11:44 AM
05-16-2024 07:01 PM
05-16-2024 04:59 AM
05-15-2024 01:32 PM
no avatar 3. Nutribun
