Attaching water bottle holders on old bikes
Hi,
How do you attach a water bottle holder to an old bike that doesn't have the screw holes for mounting them? Thank you for any input.
You can buy adaptors that fit on the handlebar or seat tube that will allow you to attach a bottle cage to them. Check with your LBS as they should carry at least one type of adaptor.
HCFR Cycling Team
There's a bunch of ideas on this link that you can use
http://recklesscognition.wordpress.com/2009/01/13/methods-for-attaching-water-bottle-cages-without-screws-and-bosses/
riv-nuts
You do not want to drill holes in your frame.
There are water bottle holders that use wrap around straps. Usually found in department stores . I got mine at Target.
You can also use the plastic cable ties , used by electricians. And there are handlebar mounts too.
(03-25-2011, 10:52 PM)GeorgeET Wrote:  You do not want to drill holes in your frame.
Ill go to the bike shop to see what they have. Tried the plastic ties, but it kept moving.
stainless steel hose clamps with a short piece of sectioned inner tube to protect the paint work great.
(03-26-2011, 02:57 AM)nfmisso Wrote:  stainless steel hose clamps with a short piece of sectioned inner tube to protect the paint work great.
With the excellent ideas above if you are worried about the paint job using this idea you can put small pieces of inner tube between the hose clamps and frame which will also help to keep it from moving.
Sounds like a good idea I'll try it thank you for all the input!
I have seen some innovative water bottles recently...
- a two bottle holder that goes under/behind the seat. You might be able to get a smaller saddlebag underneath it
- a handlebar mount (sometimes you see these on bikes with time trial handlebars)
(05-23-2011, 09:18 AM)monty3ross Wrote:  I am having a old bike so this is helpful for me.I attach a bottle holder behind the seat.
Did you read the above advice?
5,306
08-01-2021, 10:58 AM
Last Post: JohnWebike
8,938
08-14-2014, 07:00 PM
Last Post: GeorgeET
5,650
10-12-2012, 10:34 PM
Last Post: Bill
15,632
02-12-2012, 05:57 PM
Last Post: ghost
16,017
06-18-2010, 06:32 AM
Last Post: Bill
Philodo H8
Today 12:50 PM
Opinions on Bergamont bikes?
Today 11:58 AM
Today 06:44 AM
Today 06:36 AM
interpreting serial numbers
Yesterday 01:55 PM
05-17-2024 11:50 AM
05-17-2024 11:44 AM
05-16-2024 07:01 PM
05-16-2024 04:59 AM
05-15-2024 01:32 PM
no avatar 3. Nutribun
