Derailleur Hanger
After pulling off my rear derailleur I noticed that my hanger has significant play against the frame. I tried tightening the bolt but it won't tighten anymore, when I loosen it it still only tightens to the same point.
Any ideas?
Thanks
Benen
Some aluminum hangers don't just use a one piece bolt, but come in two pieces for that single bolt area...
for example
check out this photo of a two piece bolt.. similar to some crankset ring bolts
http://rowerowy.com/sklep/akcesoria/haki_do_ram/haki/prod/rdb_805_c
(updated)
If you noticed you can put a flat head screw driver of the right size to use it to hold down that bolt while tightening the other bolt with the correct hex key size.
This might be your problem since you can't tighten it enough without having the other piece held down with a flat head screw driver.
If it's not a two part bolt like haykong talks about, pull out the bolt that holds it and inspect the threads. If the threads on the bolt are damaged, you should be able to get a new one. If the threads on the frame are damaged, you've got a bigger problem unfortunately.
I think I was just tired and not looking at it properly. Tightened up no problems. Not sure what I was doing wrong the other night. Cheers for the help b
8,973
09-28-2011, 09:49 PM
50,304
05-28-2011, 09:48 AM
Last Post: ayjay
16,392
05-21-2011, 08:34 PM
Last Post: AlexM
11,542
01-13-2011, 05:53 AM
Last Post: trevgbb
Today 10:02 AM
Today 10:00 AM
Today 09:58 AM
Today 05:46 AM
04-26-2024 01:35 PM
Fair Weather Cycling
04-26-2024 10:00 AM
What was your first bicycle?
04-26-2024 09:19 AM
QUINTANA ROO "KILO" 1999
04-26-2024 09:16 AM
04-26-2024 09:10 AM
04-26-2024 12:37 AM
no avatar 1. enkei
no avatar 2. Jesper
no avatar 5. Amanda_W
