Inflated tube dislodges tyre - what's happening?
Hi I have a problem with my daughters's bike. When you inflate the tyre, all looks okay, but when she rides it, the tyre gets dislodged and the inflated tube starts popping out.
It's a relatively new bike, nothing damaged, what's happening?
Any help appreciated.
Thanks!
I would suggest you click on the link "How to fix a flat tire" and read through the section about seating and inflating the tire. Got to get that bead seated properly as well making sure the innertube is in a proper alignment.
(01-31-2013, 02:03 PM)RBurrelli Wrote:  I would suggest you click on the link "How to fix a flat tire" and read through the section about seating and inflating the tire. Got to get that bead seated properly as well making sure the innertube is in a proper alignment.
Thanks! I'm used to a kind of "point and shoot" action when re-inflating the tyre, maybe I need to take a closer look as you say.
Also look along the rim walls for a bend that might cause the seating of the tire to open up a little bit.
Hi, could it be that the tube has pinched and bulges a bit?
After checking the rim and rim tape for damage/imperfections the other thing that could be wrong is the tyre size (or tire Wink ).
If its a new bike then really it should have the correct tyre size but here is a sheldonbrown.com article in case there are doubts:
http://sheldonbrown.com/tire-sizing.html
1,135
03-24-2024, 05:48 PM
Last Post: Frankly
9,884
06-07-2015, 03:57 PM
16,113
03-30-2015, 12:18 PM
8,941
04-02-2014, 05:31 PM
Last Post: Snowpup
8,860
04-02-2014, 04:01 AM
Last Post: kevino47
12,883
02-04-2013, 08:59 AM
Last Post: andy2307
10,840
08-11-2011, 12:43 PM
Last Post: DaveM
15,916
06-17-2011, 11:19 AM
interpreting serial numbers
Yesterday 05:45 PM
05-17-2024 11:50 AM
05-17-2024 11:44 AM
Philodo H8
05-16-2024 11:56 PM
05-16-2024 07:01 PM
05-16-2024 04:59 AM
05-15-2024 01:32 PM
05-15-2024 01:27 PM
05-14-2024 08:13 PM
05-13-2024 08:40 AM
no avatar 2. Nutribun
no avatar 3. enkei
