Trek domane tyre
Hi
I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally)
The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible
Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher
Thanks
They have a screw. If you screw them in, it should bring the arm out.
Give that a try first.
(01-30-2024, 04:08 AM)RolandoZa Wrote:  Hi
Thanks
is it V-Brake or Caliper types? if it is a V type, you can usually put thicker tires that's why this type of brake was super popular with mountain biking before the advent of disc brakes, if it is a caliper there's usually a lever that you can toggle to make the caliper a little wider to fit the wheels in, 25 to 28 isn't a really huge jump and should allow your tire and wheel to fit right in. Hope this helps
Thanks
Correct, the Domane is a ROAD bike with Caliper brakes and not V-brakes. It can be set up with a 28 mm tire though you may have to fiddle with it some. In fact, I believe they are spaced for 30 or 32 mm tires. In one older bike I had to put two star washers in the space between the brake surface and the frame hanger but it worked fine. Remember that the Domane is a recent addition so it will definitely mount 28's.
5,081
02-09-2022, 02:01 AM
Last Post: Jesper
9,817
06-07-2015, 03:57 PM
16,030
03-30-2015, 12:18 PM
8,887
04-02-2014, 05:31 PM
Last Post: Snowpup
8,783
04-02-2014, 04:01 AM
Last Post: kevino47
12,795
02-04-2013, 08:59 AM
Last Post: andy2307
10,776
08-11-2011, 12:43 PM
Last Post: DaveM
15,826
06-17-2011, 11:19 AM
Today 05:04 PM
Today 01:30 PM
Vilano Warning
Today 11:17 AM
Today 05:49 AM
05-04-2024 12:32 PM
05-03-2024 02:34 AM
05-02-2024 12:40 PM
05-02-2024 12:37 PM
05-01-2024 10:57 PM
05-01-2024 10:51 PM
no avatar 5. Nutribun
