Crank on my Rockhopper creaking?
Hi got a 2011 rockhopper SL with shimano crank... i have never serviced a crank. But am a vehicle mechanic so happy to take on the job.
Whats likely to require attention when its creeking slightly when pedaling hard?
You most likely have a sealed Bottom Bracket , so no service is possible. Photos of BB would help. Creaking could be from other areas make sure all is tight especially pedals the seat and check the seat post.
First things to check are:
- remove, regrease threads, and reinstall pedals
- check tightness of crank arms onto BB
- check for side to side play in BB bearings
- If continues, might want to remove BB, check bearing smoothness (regrease threads and reinstall if bearings ok)
- creaks can also come from wheels, seatpost, seat, headset. The sounds tends to travel through the frame so it can be hard to pinpoint source. But the cranks are the most common cause and best place to start. This is a normal indicator of a loose crank which will damage the crank arm if ridden loose for long, so don't ignore...
Great response. Thank-you I will take some gear home tonight and have a look
And post some pics. Thanks Big Grin
Yesterday 10:07 PM
Yesterday 09:27 PM
Yesterday 09:22 PM
Yesterday 09:15 PM
Yesterday 03:19 PM
09-14-2026 09:03 PM
Best road bike tyres?
09-14-2026 02:12 PM
How new adventures begin..
09-12-2026 03:11 PM
Shimano RevoShift upgrade
09-12-2026 10:16 AM
09-12-2026 10:04 AM
no avatar 1. GirishH
no avatar 2. Flowrider
no avatar 3. Sidewinder
no avatar 5. ReapThaWhirlwind
