Wheel hub bearings. Room for one more ball?
Hi all.
Recently my bicycles wheel hubs are showing their age and need a proper servicing.
I have stripped down both wheel hubs and was surprised to notice that I could comfortably, without any steady handed trickery, fit two more bearings in the cup for my rear wheel hub and one more bearing in the the cups of my front wheel hub.
According to the Shimano tech document my rear hub takes nine 1/4 inch ball bearings per side and the front hub takes ten 3/16 inch balls per side.
Should I stick with what Shimano is saying or should I pack the cups with as many bearings as it can comfortably take???
You did get the correct ball size? (just asking)
It is normal that 1 additional ball might fit in (though usually it would be slightly too tight). If there's really room for one additional ball (and everything can be assembled as it should, check over locknut distance and orientation of axle) I probably would put it in.
typically if original bearing were caged, add one ball
Nope, no caged, just loose in the cup.
I have since been advised by the LBS that it is normal for the cup to not be completely filled with bearings and to simply obide by the Shimano tech docs.
This last advice is standard for any loose ball cup and cone bearing.
DO NOT ADD EXTRA BALLS EVER over the OEM design. As others have said, a less than full fit is normal, and packing more balls in (even if they fit) screws up the bearing cone/cup geometry and ball circulation; and will lead to rapid failure. I found this out the hard way by packing an extra (25th) ball into the rh ball ring of a Sturmey Archer AW 3 speed...
cheers,
AW-hub.
(10-21-2011, 07:58 PM)d3v Wrote:  Nope, no caged, just loose in the cup.
Yesterday 07:15 PM
Yesterday 07:11 PM
Yesterday 06:59 AM
10-21-2026 08:09 PM
10-21-2026 07:32 PM
10-21-2026 07:07 PM
