11-23-2014, 11:06 AM
Inexpensive bike support
11-23-2014, 12:34 PM
Almost anything that securely holds the bike far enough from the wall will work as well, such as ladder hooks: http://www.lifeandhome.com/large-ladder-hook-8-mm.html - about a buck a piece or available in almost any hardware store. They can be used with either exposed studs or on the studs of a finished wall. the 16" between studs is convenient for hanging from the top tube. That is an old low cost solution, as is attaching two ends of a rope from the rafter or eye hooks in a garage and passing them under the seat and handlebars - that was my first "bike stand."
11-23-2014, 02:50 PM
I hang my bicycles upside down from bike hooks screwed into beams in my garage. When I want to work on a bike I just throw a rope over the hook it has a loop at one end that I thread the other end through and adjust height, like lasso.
04-11-2015, 03:17 AM
1. Blunt Impact/Force
2. Heat
3. Relief Cuts
4.Rock the bolt
5.Drill'er out
5.Drill'er out
7. Air Hammer/Chisel
8. Bolt or screw extractor
9. Pipe Wrench
10. Reinstall bolts that surround the stuck bolt/nut
2. Heat
3. Relief Cuts
4.Rock the bolt
5.Drill'er out
5.Drill'er out
9. Pipe Wrench
04-11-2015, 10:30 AM
(11-23-2014, 11:06 AM)JanJ Wrote: Actually, I give my wife credit for this one....
I was discussing having access to something to hold bike up as service is done to it....... And she came up with a fantastic, and low cost solution....
Since I'm doing the work in the basement, she pointed at something we are presently using in the garage to store garden hose during the winter: 2 adjustable floor joist hooks:
http://www.farmshow.com/a_article.php?aid=18019
and some heavy rubber straps... Holds the hose quite securely.
Tried it in basement with bikes..
Positioned 2 on joists where I needed support: 2 Straps hook to these: one under rear seat frame junctions and other at handlebars/headset, and bike is held up with rubber straps!
Been using it for recent bike services quite successfully... Fantastic Idea!
I can hand crank the bike quite vigorously and have no stability issues whatsoever!
And when I'm done, I take it down, and there is nothing left hanging from -the floor rafters!!
Got a pic for us?
04-11-2015, 10:51 AM
I do like threads like these, some great ideas that I am sure work good for a low volume user. Hard to beat a shop quality stand in my book. I use a floor stand, bench mount, and a wall mount units. plus I use one of the most over looked stands that many people already own. The ole' Fluid/mag trainer holds the bike quite nicely for many tasks.
05-06-2015, 08:02 AM
(04-11-2015, 10:51 AM)painkiller Wrote: I do like threads like these, some great ideas that I am sure work good for a low volume user. Hard to beat a shop quality stand in my book. I use a floor stand, bench mount, and a wall mount units. plus I use one of the most over looked stands that many people already own. The ole' Fluid/mag trainer holds the bike quite nicely for many tasks.
It also gives you a test bed with some resistance for testing adjustments. Until recently I was hanging the bike from the ceiling with a soft rope,worked fine for what I am doing. Recently got a floor stand and man is that nice!
Bill
Nobody ever said "I wish I would have gotten less of a bike!"
Cervelo S5
Cannondale F29 1 alloy Lefty
Trek X-01 Crossbike
2017 Trek Farley 7
71 Ral Professional
72 Ral International
73 Ral Grand Sports
73 Ral Competition
74 Ral Super course
74 Ral Granprix
74 Paramount
2017 Trek Domane SLR 6
Cervelo S5
Trek X-01 Crossbike
2017 Trek Farley 7
71 Ral Professional
73 Ral Grand Sports
73 Ral Competition
74 Ral Super course
74 Ral Granprix
74 Paramount
10-27-2017, 05:57 PM
This one is a good idea. Thanks for sharing it with us.
3,894
21,276
