Sram/ultegra compatability
My bike is a Specialized Roubaix with 105 triple components (2007). Because the frame cracked Specialized is replacing my frame with a SL3 pro. I would like to upgrade some components; Sram apex 11-32 cassette, Ultegra 6700 compact crank 50-34, and Ultegra BR-6700 brakes. Will these parts be compatible and what else would I need to change when I transfer my parts to the new frame. Thanks, Michael
Just make sure the brakes have the proper reach specs, you may want to replace the chain, and you may need to change the spindle/bottom bracket
105 rear derailleur should not take a 11-32 cassette, because the largest sprocket you can put on is a 27 or 28
Is your bike have some external BB bearings like theses??
http://www.bikepedia.com/Images/image2.aspx?w=300&h=300&filename=BBST2320.jpg&f=Hawley
I can help you further if you can check on your rear and front derailleur for the model ##, it should be RD-XXX and FD-XXX
(11-14-2011, 09:51 PM)bobtravers Wrote:  105 rear derailleur should not take a 11-32 cassette, because the largest sprocket you can put on is a 27 or 28
I have purchased a sram 11-36 cassette and a SLX-RD-M663 as well as a Wippermann 10SO chain. I hope the 105 shifters will handle that derailleur. I still would like to get a Ultegra 6700 50-34 crankset. I believe the new frame takes a BB60 bottom bracket and a braze-on front derailleur (my 105 is a clamp on) so I'll need to replace them as well. Do you see any issues with this set-up? Thanks, Michael
Well mix-match of parts usually don't work very good, but, total capacity of the rear derailleur is fine... The only thing I don't know is do road shifters work with a MTB rear derailleur??? Is the ratio of cable plulled is the same on a road and MTB shifters?
Yes, most of the Shimano road and MTB RDs need the same amount of cable pull. On the conversion: I yould have gone with 3 chain rings in the front and a road cassette. The jumps on MTB cassettes are much too wide for my taste...
7,657
10-29-2019, 10:17 PM
Last Post: J_R_Schultz
4,540
10-18-2019, 06:39 PM
Last Post: Zviedrs
5,801
09-17-2015, 08:41 PM
Last Post: fishboy316
18,229
03-22-2011, 11:45 AM
Last Post: Arseneau69
Yesterday 08:14 PM
Yesterday 01:39 PM
Yesterday 01:35 PM
Yesterday 01:07 PM
Fair Weather Cycling
Yesterday 10:00 AM
What was your first bicycle?
Yesterday 09:19 AM
QUINTANA ROO "KILO" 1999
Yesterday 09:16 AM
Yesterday 09:10 AM
Yesterday 12:37 AM
04-24-2024 11:15 PM
no avatar 1. enkei
no avatar 2. Jesper
no avatar 5. Amanda_W
