Is my chain too long?
I'm hoping you guys can help me.
I picked up a road bike for someone and was going thru it just to make sure everything was ok with it. It won't up-shift from the lowest gear on the rear derailleur. When it's in first gear the bogey wheel is right down on the sprocket - and I think that's what's preventing it from shifting. The derailleur has no B-screw adjustment. Can I correct it by shortening the chain?
Thanks!
pictures needed. more information about the derailleurs and bike needed.
probably not a good idea to shorten the chain.
Thanks Nigel,
Here are photos of the rear derailleur and drive train:
http://i600.photobucket.com/albums/tt86/scoostraw/inlet%20hosting/derailleur_6.jpg
http://i600.photobucket.com/albums/tt86/scoostraw/inlet%20hosting/derailleur.jpg
http://i600.photobucket.com/albums/tt86/scoostraw/inlet%20hosting/derailleur_2.jpg
http://i600.photobucket.com/albums/tt86/scoostraw/inlet%20hosting/derailleur_5.jpg
http://i600.photobucket.com/albums/tt86/scoostraw/inlet%20hosting/derailleur_3.jpg
http://i600.photobucket.com/albums/tt86/scoostraw/inlet%20hosting/derailleur_4.jpg
I eliminated the shifter cable as a cause by disconnecting it. It just doesn't want to come off the large cog by itself. A nudge by hand and it is fine - the spring in the derailleur will then pull it all the way onto the smallest cog.
If you have any thoughts I would appreciate it.
Thanks.
Based on this:
it is time to replace the derailleur; because it's internal springs are no longer working properly. You could try rebuilding it, but the replacement springs would probably cost more than a new derailleur if you could find the right spring(s).
If I don't rebuild it, can you point me in the right direction regarding an inexpensive modern replacement? This bike has 5 speeds on the hub. - Ken
Any 5/6/7 speed Shimano derailleur will work for you.
This one for example:
http://www.amazon.com/Shimano-Tourney-TX55-Derailleur-Speed/dp/B003ZMH69S/
My commuter has a TX51; recently replaced in their line by the TX55; works well.
You should also replace the chain at the same time; follow the instructions that come with the derailleur to set the chain length.
(07-20-2011, 11:07 PM)nfmisso Wrote:  Any 5/6/7 speed Shimano derailleur will work for you.
Nigel,
You were 100% correct. My LBS sold me a Shimano RD-TY18 GS derailleur for $10. It bolted right up and works perfectly. Here is my "after" photo:
http://i600.photobucket.com/albums/tt86/scoostraw/inlet%20hosting/shimano_derailleur.jpg
What is the main difference between this one and the one you mentioned?
Thanks again.
The RD-TY18 was discontinued several years ago - but other than that, there aren't any significant differences.
8,722
12-10-2016, 10:46 PM
Last Post: ccronin4
4,006
06-04-2013, 05:34 AM
Last Post: DaveM
15,762
05-22-2010, 05:42 PM
Last Post: trevgbb
Today 06:44 AM
Today 06:36 AM
Philodo H8
Today 06:03 AM
interpreting serial numbers
Yesterday 01:55 PM
05-17-2024 11:50 AM
05-17-2024 11:44 AM
05-16-2024 07:01 PM
05-16-2024 04:59 AM
05-15-2024 01:32 PM
05-15-2024 01:27 PM
no avatar 2. Nutribun
no avatar 3. enkei
