A 29 inch mountain bike, can run mountain bike tires, gravel tires, or road tires
Some people are not sure what type of bike to buy. If you buy a 29 inch mountain bike, you can run mountain bike tires, gravel tires, or road tires. Then decide which you prefer.
There may be some 29 inch mountain bikes that are different, but on my bike, the rims are narrow enough to run road tires.
Some people might want to use one type of tire for summer, and another for winter. You can just swap the tires.
If you go the other way, and buy a road bike, the space between the frame is too narrow, so you can't run wide tires.
You mean knobby tires, semi-slick tires, or slick tires?
When you say road, it begins to suggest width of the tire.
'I had tried buying 1.25" Continental Contact Speed for my 27.5" street racer convert. Tires that narrow provide bad versatility for bumps and look gaudy between the wide stays. That's when I opted for the 2.00" version. Which are like balloon tires. I rode them overclocked at 70psi and they were fantastic.
On my mountain bike I have mountain bike tires. If I wanted to ride long distances on good roads, I could switch the tires to narrower road bike tires. These would give less rolling resistance, and enable me to go faster and further.
There are some people with little experience with bikes, who don't really know what type of bike they want. They could get a bike like this, and try different tires to see what they like.
In reality, like you, I am running my rear mountain bike tire at higher than normal pressure, to reduce rolling resistance while on good roads, while still being able to go off road.
The tires that came with the bike are rated at a maximum pressure of 40psi. I have left one of those on the front. I changed the back tire so I can run it at a higher pressure, and will use the original back tire on the front, when the front tire is worn out. When both 40psi tires are worn out, I will probably run high pressure both front and back.
You realize that off-road is better with lower tire pressure?
If you're overclocking them, you're suffering off-road.
I usually ride my winter bike at low 40psi or a little less.
(02-13-2023, 02:21 PM)ichitan Wrote:  Some people are not sure what type of bike to buy. If you buy a 29 inch mountain bike, you can run mountain bike tires, gravel tires, or road tires. Then decide which you prefer.
Yes, you can run road and gravel tires on a mountaim bike, it'll look weird but it will work, mountain bikes are much more affordable than road bikes here in the Philippines so alot of the more impoverished cyclists here opt to install road or gravel tires on their mountain bikes since they dont actually go on trails and they cant afford a proper road bike.
(03-06-2023, 01:13 AM)ReapThaWhirlwind Wrote:  You realize that off-road is better with lower tire pressure?
I often ride on road, to a place where I ride off road, and later ride on road to go home again. My aim is to have the best pressure for all situations, and not change it every time the road changes.
(03-06-2023, 11:14 PM)meamoantonio Wrote:  Yes, you can run road and gravel tires on a mountaim bike, it'll look weird but it will work, mountain bikes are much more affordable than road bikes here in the Philippines so alot of the more impoverished cyclists here opt to install road or gravel tires on their mountain bikes since they dont actually go on trails and they cant afford a proper road bike.
If you get in a situation where you are riding in wet clay, it sticks to the tire, then the frame. Having a big space between the tire an the frame is an advantage.
My situation is the same.
I run 26 x 1.5 Specialized Nimbus 2 Sport tires at 80psi. They handle off-road okay so long as it's dry.
Shifting way down adjusts what you need in simple passes.
Today 04:59 AM
Today 03:43 AM
Yesterday 01:32 PM
Yesterday 01:27 PM
05-14-2024 08:13 PM
05-14-2024 06:22 PM
05-13-2024 08:40 AM
Fat bikes for ever..
05-13-2024 04:17 AM
Receive post notifications
05-13-2024 03:22 AM
05-13-2024 01:51 AM
no avatar 3. enkei
no avatar 4. Nutribun
