Viscount Aerospace
Hi. I am trying to renovate a Viscount Aerospace and am having difficulty with the bottom bracket. The shell is normal 68mm, but has pressed in 35MM bearings (not BB30) and a 119 mm spindle that (obviously) passes through these bearings.
Bearings are easy to find, less so the spindle! The spindle has been damaged (not by me) and is useless. I have tried all the places I know to find a spindle, but cannot locate. So am toying with the idea of fitting a sealed bottom bracket (the damaged thread, repair type, as the shell is not threaded and too thin to try and thread). Has anyone got experience of this? or know where I can find a replacement spindle.
Many thanks
You are not going to find the spindle as far as I know. A threadless BB should work fine. http://store.velo-orange.com/index.php/components/bottom-brackets/grand-cru-threadless-bottom-brackets.html. Make absolutely sure that the bike has a steel fork, not the original defective/recalled aluminum one.
I would go with our friend from Syracuse recommendation.
If you are a brave soul with $$$$ to spare, you could take the old spindle to a machine shop and inquire about duplicating it. The replacement needs to be 4340 or similar high strength alloy steel, and be hardened to around Rc40-45.
Thanks for the replies - Threadless BB it is! The fork is OK, as far as i can tell this is a Mk3 with a "proper" steel fork.
04-24-2024 11:15 PM
04-24-2024 09:11 PM
04-24-2024 01:55 PM
2010 Specialized Hardrock
04-23-2024 05:54 AM
QUINTANA ROO "KILO" 1999
04-22-2024 02:04 PM
04-22-2024 01:35 PM
04-22-2024 01:31 PM
04-22-2024 01:26 PM
04-22-2024 01:12 PM
Fat bikes for ever..
04-22-2024 12:23 PM
no avatar 5. TrailJoe
