Noob Needs Help with Saddle Post Clamp Ordering
The bottom part of the clamp that secures my saddle broke. I have some pictures:
[Image: kbzZeq5.jpg]
You can see how the bottom clamp is broke and bent. I think someone was trying to steal the seat. Where can I order this part online?
and here is the bike, trek 730
[Image: e3TVIKA.jpg]
The saddle is from a Canadia firm called spider, it's noseless. Thanks in advance.
I been riding this bike to work every day for like 10 years now.
You need to determine the diameter of your saddle post first. Than check with google or amazon. I doubt you can find repair parts, buy you can get a new post for $15 or so. Check with your local bike dealer.
Looks like 1 inch in diameter.
There are lots of seats close to one inch from 25.4 mm (1") to 27.2mm. Seat post needs to be measured very carefully.
http://www.walmart.com/ip/13012241?wmlspartner=wlpa&selectedSellerId=3&adid=22222222227000000000&wl0=&wl1=g&wl2=c&wl3=21486607510&wl4=&wl5=pla&wl6=19880599990&veh=sem
Looks like it's 26.6 millimeters. I never would've thought there could be a difference of 1mm.
my bike on bikepedia
(09-26-2013, 12:42 PM)ro8ter Wrote:  Looks like it's 26.6 millimeters. I never would've thought there could be a difference of 1mm.
That helps ye the differences can be very small. Look around maybe you can just swap parts from a used one.Take it to a local dealer. Not everything is solved with a computer.
http://www.amazon.com/Sunlite-Alloy-350mm-Seat-Post/dp/B000AOZ1L4
I would check the stamping on the post you have, it should tell you. Look closer. Some of those Treks came with a post shim from the factory. If your post was swapped at some point in time and you ordered the 26.6 and it had a shim from the factory it will not fit right. Check twice buy once
Yup. Seat posts are sold in .2mm increments. If you are off by a size it will not fit - either only brute force will make it go down or you need to almost brake the clamp to fix it - and then it will still slip at the most inconvenient point in time. The LBS has a tool to measure the inner diameter of the seat tube. When in doubt: let them measure but then also order from them (this will not really be more expensive than shopping online)
1,923
03-28-2021, 01:04 PM
Last Post: Hutch6447
6,591
06-04-2017, 04:16 PM
Last Post: Eugbug
2,947
10-25-2015, 06:23 AM
Last Post: Eugbug
19,352
10-06-2015, 05:42 PM
Last Post: Old Duane
11,983
02-25-2013, 09:47 PM
Last Post: erikbear
Today 05:48 AM
Yesterday 07:01 PM
Yesterday 04:59 AM
Yesterday 03:43 AM
05-15-2024 01:32 PM
05-15-2024 01:27 PM
05-14-2024 08:13 PM
05-13-2024 08:40 AM
Fat bikes for ever..
05-13-2024 04:17 AM
Receive post notifications
05-13-2024 03:22 AM
no avatar 3. enkei
no avatar 4. Nutribun
