External Bearing Crank Removal
Hi guys,
I'm probably bugging you all quite chronically now with my lamo questions that make me sound like an illiterate person trying to write a novel backwards upside down underwater, so apologies in advance.
Ok, I just want to check that it's definitely possible to remove external bearing cranks with an 8mm allen key (Truvativ in my case). I've WD40d the whole area so I'm leaving it for now. But I shall be returning to try to remove them again so I just want to be sure there isn't a safer way to get them off.
Cheers fellas and felines
Si
No, that's good, put the longest 8mm Allen key you got in, and tap on the key with a rubber mallet to remove the bolt if it's not possible to remove by hand... Another way is to put a long tube over the Allen Key, what is called a "cheater bar"... Be sure that the key is in good place over the bolt before applying force, or you can round off the bolt!
(04-28-2011, 08:33 PM)bobtravers Wrote:  No, that's good, put the longest 8mm Allen key you got in, and tap on the key with a rubber mallet to remove the bolt if it's not possible to remove by hand... Another way is to put a long tube over the Allen Key, what is called a "cheater bar"... Be sure that the key is in good place over the bolt before applying force, or you can round off the bolt!
Why thank you very much Bob, you're a fine fellow.
I shall take heed of your advice.
Si
have a look here;
http://www.sram.com/truvativ/category/42
(04-29-2011, 03:09 PM)trevgbb Wrote:  have a look here;
Forgive my rudeness, but what am I meant to be looking at here?
The link led me to the Truvativ range of bottom brackets.
Si
Si
I assume from the wording of your question you are talking about a truvativ bb with external bearings, which is where this link takes you, you will see on further exploration there is a link to " service", where you may find the answer to your question.
Si
Oh right, thanks buddy. All understood now.
You'll be pleased to know I managed to get the cranks off yesterday with just my 8mm allen key & some good old fashioned man strength. Was on really tight!!
So it should run nice & smooth now I've cleaned it all & regreased everywhere.
Si
68,837
08-25-2025, 06:12 PM
Last Post: eugeneh
2,747
10-22-2024, 09:38 AM
Last Post: rydabent
13,314
08-14-2022, 07:32 AM
Last Post: ichitan
39,682
07-19-2021, 12:00 AM
Last Post: rbx
6,729
02-27-2021, 07:52 PM
Last Post: rob keith
2007 Trek Pilot S.P.A. 5.2
Today 05:40 PM
Today 04:23 PM
Today 03:51 PM
Yesterday 08:38 PM
Yesterday 05:50 PM
Yesterday 05:41 PM
Yesterday 05:10 PM
Yesterday 01:11 PM
Yesterday 07:42 AM
Spoke Count Preference
09-30-2026 12:29 PM
no avatar 1. Sidewinder
no avatar 2. Flowrider
