How often check or change mechanical disc brakes
I'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads?
I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way.
However, a few weeks later, while descending steep hills, I started feeling like my wheel might come off. It was alarming, and I thought something might be stuck between the pad and the brake rotor. I removed and readjusted the wheel, but the problem persisted.
Finally, after tackling a few more steep sections, I found a motorbike repair shop in a remote mountain village (there were no bicycle shops around). To my surprise, I discovered that one of my brake pads was completely worn out, which explained why the wheel felt unstable when I applied the brakes.
Fortunately, I had a spare set of brake pads, so I replaced them, and the problem was resolved. This experience got me thinking—how often should one check brake pads during long rides?
Interestingly, I noticed the spring was broken as well, but I didn’t have a spare. I had to make do with it for the rest of the trip. What role does the spring actually play in brake performance?
Once I reached a larger town, I replaced all the brake pads and springs. However, one of the springs isn’t sitting properly, despite trying all the tips and tricks I’ve read or watched online. I’ve even ridden 50+ miles with the spring slightly misaligned, but I still can’t get it to sit snugly.
Does anyone have pointers or advice on this?
Attached Files Image(s)
I assume the noise was from the pad holder contacting the rotor directly. Like a car they are easy to view and to see excessive wear of the pad and rotor.
Again, my problem exists from the professional mechanic who sent yoi on yourxway with obviously wore out brake pads. Insane; andcyou paid to be put nack on the road with an unsafe bike. Typical bike shop service nowadays!
Thanks, @Jake1. That experience made me to keep my shut while at a bike-shop. I visited the shop just about when he's ready to close and I was excited to chat with a fellow cyclist.
I have a feeling if I had taken the bike another time, he would have caught the issue.
But, still it's on me. I need to learn to check the basics especially when I have put a few thousands miles on this bike.
Hence, my question about the length or duration folks check/change brakes.
(11-30-2024, 01:47 PM)GirishH Wrote:  Thanks, @Jake1. That experience made me to keep my shut while at a bike-shop. I visited the shop just about when he's ready to close and I was excited to chat with a fellow cyclist.
I think for your style of riding and mileage you kinda answered your own question. You have taken them just past the limit. Now just subtract a couple hundred miles. there really is not one formula except a visual inspection now and again. you are a packer so you will wear faster, the more down hills and more weight will wear faster.
Thanks, @Painkiller. After I changed them, I realised how easy it was. Not sure why I was so scared of them all this while. I will definitely inspect them more often now than past..
Strava is a good tool to use to keep track of your bike's mileage, I change my pads once a year with 5000 - 7000 kms in mileage, im also a heavy rider so obviously this would add more wear on the pads too
Most likely depending on the mileage. I myself change pads the moment the lining was thinner compared to a quarter.
Thanks, @Nutribun. To see how much "lining" you have, do you pull the pads out or just measure while they are still inside the disc brake setup?
Thanks.
(12-09-2024, 12:44 AM)Nutribun Wrote:  Most likely depending on the mileage. I myself change pads the moment the lining was thinner compared to a quarter.
This wants to be the kind of issue that answers itself. But I would check mine every time I maintenance the bike, for cleaning. They get dirty so quickly it seems. I'm constantly cleaning them. I can't imagine wearing mine out in a year, but I would probably replace mine on the second year for performance alone. I don't like to wear my components down to the bone. Once they begin to lose performance, I tend to replace them.
Hey @GirishH, after going through this information, what solution did you come up with?
Hello @Flowrider, Now, I check my brakes almost daily and adjust them just as often—especially since I'm riding in the Indian Himalayas, where the gradients are much steeper than I'm comfortable with. So, I ride those brakes..
The last time I rode down a particularly steep hill, I found I couldn’t stop. Even using my feet didn’t help. When I finally managed to stop and went to adjust my brakes, they were so hot I couldn’t even touch the housing. I had to wait about 40-60 minutes for them to cool down before I could make any adjustments and get back on the road.
And that was just on my way to the Himalayas!
So, everytime I start I adjust brakes and make it a point that they have "enough" thread left in them.
(06-15-2025, 06:55 AM)Flowrider Wrote:  Hey @GirishH, after going through this information, what solution did you come up with?
Thanks for that @GirishH. You are currently facing exceptional circumstances. Safety first, so a daily check is necessary.
I honestly can't imagine riding more than two seasons without replacing pads.
It doesn't matter what brake type they are.
(06-18-2025, 01:02 AM)GirishH Wrote:  The last time I rode down a particularly steep hill, I found I couldn’t stop. Even using my feet didn’t help. When I finally managed to stop and went to adjust my brakes, they were so hot I couldn’t even touch the housing. I had to wait about 40-60 minutes for them to cool down before I could make any adjustments and get back on the road.
Your brakes shouldn't be getting that hot. They do get hot enough to burn you, but shouldn't need the best part of an hour to cool down afterwards. Were you riding the brakes or using them intermittently? It can be unnerving on a steep hill, especially with a heavily loaded bike, to use the brakes like that, but it's vital to give the brakes some time to cool off. If necessary, come to a complete stop every now and then.
Yesterday 03:17 PM
How new adventures begin..
Yesterday 03:11 PM
Yesterday 12:10 PM
Yesterday 11:16 AM
Shimano RevoShift upgrade
Yesterday 10:16 AM
Yesterday 10:04 AM
09-11-2026 04:39 PM
09-10-2026 08:53 AM
09-07-2026 06:32 PM
09-07-2026 05:42 PM
no avatar 3. SPINMAN
no avatar 5. froze
