Remove Hub End Caps
How can I remove the hub end caps from my front wheel? The wheel is a 2014 TBC Revolution Trail 27.5 with 32 spokes. I tried pulling them off by hand and with a pair of pliers but was unsuccessful.
The reason I'm doing this is because I noticed movement when I grip the wheel and move it side to side. I suspect the hub bearings and would like to remove the caps to have closer look and possible replace the bearings.
Here are some pictures of the wheel and hub:
[Image: 2nvs56h.jpg]
[Image: 2lieeip.jpg]
[Image: 2qjhhxg.jpg]
[Image: ojpb43.jpg]
[Image: mjmuzo.jpg]
insert your thru axle in to the end about 3/4 in and pry side to side to pop out the ends. do this on each side
(08-11-2015, 05:59 PM)painkiller Wrote:  insert your thru axle in to the end about 3/4 in and pry side to side to pop out the ends. do this on each side
I tried that too...with the threaded end. I would use the other end but I don't see how to remove the the quick release lever. Here is pic of the axle:
[Image: 2q0t213.jpg]
what brand hub are we working with?
(08-11-2015, 06:47 PM)painkiller Wrote:  what brand hub are we working with?
Transition Bike Company
no help there, if the caps do not move, they may screw on. Some brands do. try a strap wrench and pry it up with that maybe. it would also spin them if they are screw on type
You may be able to use a rubber/plastic or dead blow mallet to pop them off also
(08-11-2015, 07:01 PM)painkiller Wrote:  no help there, if the caps do not move, they may screw on. Some brands do. try a strap wrench and pry it up with that maybe. it would also spin them if they are screw on type
If only I had those tools...
After I make a trip to the hardware store I'll give it a shot.
Neither of these methods worked for me. :-(
wow, tough one. one other technique would be to clamp in a vice and pop the wheel off the caps that way. Jaw covers are nice for this so you do not scratch the parts. also do clamp so hard that you deform the caps
Brought the wheel to my LBS and he was able to remove the endcaps using the threaded side of the axle. I just wasn't using enough force when I tried it. Guess you can't be scared of it... Smile
good deal, I was beginning to wonder what the heck!
Quixy
5,862
06-27-2016, 04:53 PM
Last Post: DaveM
17,033
02-16-2015, 09:41 PM
Last Post: budstutor
16,862
04-25-2014, 10:01 AM
Last Post: sauroman1
25,650
12-12-2011, 03:41 AM
11,937
08-28-2011, 05:13 PM
11,120
08-22-2010, 01:39 PM
Last Post: DaveM
Yesterday 11:42 PM
Yesterday 08:38 PM
Yesterday 08:34 PM
Yesterday 05:50 PM
Yesterday 05:41 PM
Yesterday 05:10 PM
Yesterday 01:11 PM
Yesterday 07:42 AM
Spoke Count Preference
09-30-2026 12:29 PM
09-30-2026 12:23 PM
no avatar 2. Sidewinder
