Block spacer
My new 10 speed Shimano 105 block came with a skinny aluminum spacer, which was intended to fit behind the block.  Does this always need to be fitted or is it for special circumstances?  I also have new 10 speed specific wheels and the chain does clear the spokes without the spacer.  The new chain is not smooth under pressure, could taking out the spacer be a solution?   Thanks.
If the lock ring on the cassette tightens down well without the spacer, I don't think you "need" it. But 10 spd cassettes were designed to be used with a 1 mm spacer behind them when installed on 9/10 compatible freehubs. You should probably use it unless there is a reason not to.
I doubt any of this will affect the chain not being "smooth". Can you describe more what you mean by that?
Super Narrow 10-speed HG chains
(03-20-2015, 08:00 AM)limey Wrote:  My new 10 speed Shimano 105 block came with a skinny aluminum spacer, which was intended to fit behind the block.  Does this always need to be fitted or is it for special circumstances?  I also have new 10 speed specific wheels and the chain does clear the spokes without the spacer.  The new chain is not smooth under pressure, could taking out the spacer be a solution?   Thanks.
I see that set up uses a Super Narrow 10-speed HG chains? Anyway in case you haven't seen it here is the Shimano Video for that set up. I think? Hope it works.
http://www.bing.com/videos/search?q=video+for+installing+a+shimano+105+5700+10+speed+cassette&FORM=VIRE14#view=detail&mid=973EB6A63ABECCDDE4BF973EB6A63ABECCDDE4BF
I cliked on the link and it brought another video up. However if you click the arrow point left I think it will take you the to Shimano company video? Sorry but that is the best I can do.
4,836
07-18-2020, 05:27 AM
Last Post: Jesper
17,943
01-15-2014, 09:13 AM
Last Post: limey
13,237
11-01-2011, 11:50 AM
Last Post: trevgbb
17,011
08-16-2010, 03:23 PM
Last Post: jimlowe
14,941
06-06-2010, 10:22 AM
Last Post: cyclerUK
14,384
09-29-2008, 01:00 PM
Last Post: DaveM
Today 10:29 PM
Today 10:15 PM
Today 09:56 PM
11-05-2026 08:22 PM
11-05-2026 08:15 PM
11-04-2026 05:51 AM
11-03-2026 04:46 PM
no avatar 4. ReapThaWhirlwind
