02-18-2014, 08:15 PM
Hey guys,
First post here. I've tried searching, but I don't know what you call this.
I have a vintage Schwinn Passage that I picked up a few months ago. At first it worked well, but recently it's been giving me trouble.
When I shift, the chain pops into the higher (larger) gear, but then sits on top of the chain ring. What ends up happening is that the chainring will keep turning, and eventually the chain will pop into place or pop right off.
![[Image: 5f9NtSN.jpg]](http://i.imgur.com/5f9NtSN.jpg)
I have replaced the rear derailleur, adjusted the F&R derailleurs, and just replaced the Chain because the last one was right at the edge of needing replacement. The problem still persists. I assume the fault has to be in the front derailleur or the chain ring.
Any idea of what is happening?
Mike
Mike
![[Image: 5r9kDW0l.jpg]](http://i.imgur.com/5r9kDW0l.jpg)
![[Image: 0fIS6hwl.jpg]](http://i.imgur.com/0fIS6hwl.jpg)
![[Image: bE0DsLyl.jpg]](http://i.imgur.com/bE0DsLyl.jpg)
![[Image: FPqpMlGl.jpg]](http://i.imgur.com/FPqpMlGl.jpg)
![[Image: lF2aCrfl.jpg]](http://i.imgur.com/lF2aCrfl.jpg)
