Rear derailleur replacement
Hi,
I have a Giant bicycle and the rear derailleur has gotten bent...It is a shimano 7 speed RD-MR40. I can't seem to find a direct replacement. Any advice on a compatible replacement (keeping low to mid budget in mind)?
thanks
Look for Shimano Tourney, but pretty much any Shimano long cage rear derailleur should work.
http://www.google.co.uk/#q=shimano+tourney+rear+derailleur&hl=en&newwindow=1&safe=off&tbs=p_ord:p&tbm=shop&ei=y6XnT4vOFIee8gPrhZy0Cg&start=10&sa=N&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=ab45a42f4a7674a1&biw=1304&bih=1062
(06-24-2012, 04:34 PM)mrshanno Wrote:  Hi,
thanks
you can probably bend it back into place if nothing is actually broken. take a picture?
You cannot unbend metal. Sorry.
What is actually bent? The dérailleur or the hanger? The hanger can be fixed in a couple of minutes using the correct tools. When the dérailleur gets damaged you should always check the alignment of the hanger anyway.
(06-25-2012, 09:52 AM)Joe_W Wrote:  You cannot unbend metal. Sorry.
cannot unbend metal!? i have bent at least a half dozen derailleur cages and/or hangers back into functioning shape at our shop in the past month alone. are they as strong as they were before? no. are they a little bit more likely to break completely the next time you take a fall? yes. is this a cheap way to get your derailleur working perfectly again? yes!
I will take a picture and post it tonight to see if it can be salvaged...thanks for your help!
I know the integrated hanger on the steel frame its bent some, as well as the cage plate for the lower pulley on the derailleur itself.
In case it can't be fixed, thanks for the replacement suggestions.
In these pictures hopefully you can see the bent hanger in the first picture and the bent cage for the lower pulley in other pictures. In the last picture of the hanger, you can see where a screw appears to be missing. I apologize for the quality of the pictures, I can take them again if it's helpful.
Thanks again!
bent hanger
bent cage
bent cage
Missing screw on cage
The bent hanger should be easy enough, I've seen worse than that, here's how: http://www.utahmountainbiking.com/fix/rhanger.htm
In addition to the method shown in the link above, I would buy a couple of nuts to go on the bolt, then tighten them either side of the hanger, this will spread the load a bit and there's less chance of damaging the thread in the hanger.
I have also done it without a bolt, just using a large adjustable spanner nipped up either side of the hanger and using it to lever the hanger straight. Just do it gently and slowly and don't use a hammer on it.
The derailleur cage could probably be fixed as well, but given that you've lost a bolt and a similar new one would cost around $10.00, I would be inclined to replace it.
Thanks for all your help and the links...I certainly can fix the bent hanger using the method shown.
As for a replacment, I'm not sure if this is a "long cage", but do you think it would work (see link below)?
Shimano Tourney TX75
Should do the trick, shop around though, you might be able to find it a bit cheaper. Try Google shopping.
After seeing the pictures I will chime in now.
replace the derailleur. buy this tool first
http://www.parktool.com/product/derailleur-hanger-alignment-gauge-dag-2
do not dilly dack around with threaded rod and straight blades
This tool is critical for perfecting shifting imperfections and performance issues. Always start with making sure the wheel is true first
a nice set of calipers goes well too
use the 4 point method and align to 1mm to 2mm top to bottom and side to side
you will use this tool more often than you think
a must have for anyone wanting to be a bicycle mechanic at any level
It's quite an expensive tool, £50.00 is fine if you're a bike mechanic and going to get plenty of use out of it, but it's way too much to be economical for a one-off repair.
(06-25-2012, 09:03 PM)xerxes Wrote:  It's quite an expensive tool, £50.00 is fine if you're a bike mechanic and going to get plenty of use out of it, but it's way too much to be economical for a one-off repair.
for a one off repair? or a lifetime of tune-ups even if only used as a check gauge..MMmm sorry, Disagree on this one. the price is chump change when you consider the ease of use and how much time you save using it. not to mention the money it can make you over the years. Sure, one could use the spartan method and get the bike usable. I just wanted to give good advice as to how it is really done and the best way over the long run.
" Learn from a pro and become a pro, learn from an amateur and become an amateur " man! I hate that old saying. Sad
Thanks to all who posted advice...I ended up taking it to a bike shop and for $20 including parts/labor I'm back in the game. I guess I could have done it myself like I planned for the learning experience, but decided I would feel better having him make all the adjustments, etc.
I appreciate it.
Ye it always helps to have a good relationship with your local bike shop. Some do it yourself repairs can get costly. Also some items loose warranty when home installed.
Strange New Tire-Repair Trend?
Today 11:59 AM
Today 11:37 AM
Yesterday 04:29 PM
How new adventures begin..
Yesterday 12:31 PM
11-27-2026 05:27 AM
11-26-2026 11:36 PM
11-26-2026 07:57 PM
11-26-2026 11:14 AM
Rhoades Car (4 Wheel bicycle)
11-26-2026 10:55 AM
11-24-2026 02:13 PM
no avatar 3. SPINMAN
