Gearing ratio far too light
Folks
I'm looking for some advice
I have a boardman team c 2010 spec and I fond that I run out if gears on a descent.
The set up is as follows front and rear mechs SRAM rival rear is short gauge
Shimano hg 5600 10 SPd cassette 12-25.
Shimano hg5600 chain
Chainset is the SRAM gxp 50/34
And SRAM rival shifters
So what I'm looking to find out is a possible set up that's a bit more meaty
Any suggestions would be greatly appreciated
I would try a bigger ring in the chainset. I have a 28/38/48 on my mountain bike. Most of the time I hear of people having 54 teeth in the front.
you need to spec the maximum teeth your front derailluer can handle between rings
15 to 22 on most setups
53/39 for example
you should be running an 11t on the rear also
but remember you will probably have to replace your chain
As mentioned above, get a cassette with an 11t smallest sprocket.
http://www.sheldonbrown.com/k10.shtml#shimano9
The GXP is offered in 53/39.
http://www.sram.com/sram/road/products/s900-gxp-crankset
The Red group goes to 55/42
http://www.sram.com/sram/road/products/sram-red-crankset
I don't know the BCD, 130mm maybe ? Harris has 54T chainrings in 130mm BCD
http://sheldonbrown.com/harris/chainrings/130.html
and 110mm
http://sheldonbrown.com/harris/chainrings/110.html
See here for how to measure BCD:
http://sheldonbrown.com/harris/chainrings.html
53/11 is 15% taller than the 50/12 you currently have.
55/11 is 20% taller than the 50/12 you currently have.
You will need a new longer chain if you change the chain rings
Folks
Thanx a million for the advice
Looks like I've a little bit of work to do then
I'll let you know how I fare
Thanx
3,442
09-01-2024, 03:20 AM
Last Post: Talha
3,448
06-12-2021, 10:48 AM
Last Post: MilesBatty
10,836
04-05-2020, 05:39 PM
Last Post: CharleyFarley
10,933
12-08-2019, 05:30 AM
10,531
12-10-2016, 10:46 PM
Last Post: ccronin4
15,425
06-30-2015, 02:49 PM
115,204
01-05-2015, 07:17 AM
Last Post: slythgoe
