Sun Cruiser 7 components
Thanks in advance for your help. I would like to replace the bearings and races in the rear hub of my Sun Cruiser 7. The bearings are loose. What size bearings and races are recommended? Feel free to make favorable recommendations.
Generally races (cups) in the hub are not replaceable.
The cones on the axle are replaceable, and can be ordered from Amazon or purchased at any bike shop.
Rear hub balls are almost always ¼" diameter, but you should measure to make sure. They can be purchased from an industrial supply, Amazon or any bike shop. Grade 25 is the worst you should use; Grade 10 are better. The lower the number the more consistent the ball sizes are.
Use a water resistant grease, such as boat trailer wheel bearing grease.
(12-13-2013, 08:17 PM)nfmisso Wrote:  Generally races (cups) in the hub are not replaceable.
Thank you for the quick reply. The info is certainly very helpful!
(12-13-2013, 07:14 PM)pughr Wrote:  I would like to replace the bearings and races in the rear hub of my Sun Cruiser 7. The bearings are loose.
Take the bearings out & inspect the cups & cones. The chances of you needing anything other than bearings & grease are very slim.
Today 12:50 AM
Yesterday 01:49 PM
Yesterday 12:32 PM
05-03-2024 12:13 PM
05-03-2024 02:34 AM
05-02-2024 12:40 PM
05-02-2024 12:37 PM
05-01-2024 10:57 PM
05-01-2024 10:51 PM
05-01-2024 09:57 PM
no avatar 5. TrailJoe
