Lighter fork for Trek 4300
I have a Trek 4300 (2011)
IT has this fork: Spinner 300, 100mm travel
I want to replace this fork with one with no shock absorbers so it is lighter and helps me gain speed. As is I am locking the suspension when I am riding and not using it.
Which fork would you recommend?
you probably have a zero-stack or semi-integrated headset so your only options would be a carbon fiber or aluminum fork. the least expensive would be aluminum then carbon from a lower end name like these
http://www.ebay.com/itm/Bicycle-2011-Mosso-MTB-Aluminium-7005-Rigid-Straight-Fork-Disc-Only-Black-White-/120988100723?_trksid=p4069.m2059&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D309​6774899469490202%26pid%3D100039%26prg%3D1011%26rk%3D2%26sd%3D320946155716%26
http://www.ebay.com/itm/MOSSO-HM-Carbon-Fiber-Straight-MTB-Fork-Disc-only-/320946155716?_trksid=p4069.m2059&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D309​6785414623172727%26pid%3D100039%26prg%3D1011%26rk%3D2%26sd%3D120988100723%26
http://www.ebay.com/itm/TRIGON-FULL-CARBON-RIGID-MTB-XC-Disc-FORK-26-480g-/230862904538?pt=Cycling_Parts_Accessories&hash=item35c0805cda
more common name brands would be quite higher. I have not used the Mosso brand, I have used the Trigon Carbon with V-brakes and found them to have flex @ the Bosses which would require a beefer to be used
but with the disc version that would not be an issue
I think the mosso carbon has an aluminum steerer tube and the trigon is all carbon
your bike was intended for a shock so it will be a give and take to go rigid with that style headset. if you do not have disc brakes I would go with the Mosso aluminum. If you do have discs just flip a coin , its up to the pocket book
So you want a replacement fork that is not a suspension fork? First thing is to give us a little more information like what type of headset is used on it and the measurement of the headset.
I did find this information...
http://www.spinner-usa.com/2010/e/spinner-300.html .
User manual..
http://www.spinner-usa.com/2010/manual/2010%20Spinner%20Coil-Suspension%20Fork%20Manual%2002.pdf
I have V Brakes
Head set for Trek 4300: 1 1/8" threadless Semi integrated
Funny, I wish I had that fork! It's better than anything I have.
As bob suggested one of the above may be what you need!
16,772
07-31-2014, 09:15 PM
Last Post: barney
Yesterday 10:57 PM
Yesterday 10:51 PM
Yesterday 09:59 PM
Yesterday 09:57 PM
Hardtail Party
Yesterday 10:46 AM
Yesterday 10:40 AM
Rear hub issue
Yesterday 10:31 AM
Yesterday 07:18 AM
Yesterday 06:55 AM
no avatar 5. Frankly
