How do I connect this brake assembly?
So far I have connected the lever but there is no tension. How do I connect it to the brake assembly? Thanks.
(01-19-2011, 06:48 PM)eorta7 Wrote:  So far I have connected the lever but there is no tension. How do I connect it to the brake assembly? Thanks.
here is a picture of the lever.
I can't tell from the picture if you actually have the brake cable attached to this assembly or not. It does not look like it.
eorta - in the first (very fuzzy) pic of the caliper, in the Top Right corner, is the part that your cable housing should fit into. It looks to be upside-down but, that depends on your cable routing. The cupped end is the side that accepts the housing.
Check out this video: http://bikeride.com/sidepull-caliper-brakes/
(01-19-2011, 07:50 PM)RBurrelli Wrote:  I can't tell from the picture if you actually have the brake cable attached to this assembly or not. It does not look like it.
I don't have it attached to the assembly. I have it attached to the lever but it is not in there tight for some reason.
When you get it attached to the brake unit at the wheel and adjusted it should then fell better at the lever.
It won't tighten up until you connect the cable to the caliper (assembly). After that it will tighten up.
It might just be a blurry picture, but it looks like your caliper only has one nut on the end of the rod that the two arms pivot on. (The end facing out in the picture) If so, you may have a problem with the arms of the brake loosening up and even falling off. There is normally two nuts (one to adjust and one to lock the arms on). This is a safety issue so check it out (post better picture, compare to other calipers, etc.) Note that this is completely unrelated to how you run/adjust the cable. I just point it out to make sure the brake doesn't come apart on you.
Yesterday 05:23 PM
11-16-2026 07:09 PM
11-16-2026 07:01 PM
11-16-2026 06:56 PM
11-16-2026 06:54 PM
11-16-2026 05:29 PM
