New: Take Part in the May's Giveaway: Win the LIVALL PikaBoost 2 E-bike Conversion Kit
Front derailleur spring
What is the front derailleur spring supposed to be connected to? Mine is loose so there is no tension to move the derailleur back in toward the frame. The coiled spring ends in about a 1 inch hook but I do not see what it would hook on to.
Would need a photo to help you out.
here are some pics, a couple aren't the best. The red arrow is pointing at the hook I was talking about.
[Image: GD1N8l.jpg]
[Image: y2JIMl.jpg]
[Image: C8BTwl.jpg]
[Image: 7Mni1l.jpg]
ignore the wild shift cable and the height of the der.
It looks like it should ghook around the upper pivot of the outer arm, but it looks like something might be missing. I can't see what model it is, do you know? If so, we could compare it to a similar one if we can find a picture.
it is a Shimano Fd-Tz31 Tourney Bp 28.6 Trpl 48T Bk
I can't find a decent picture, but I'm fairly certain I'm right, if I'm not it won't do any harm and you'll be no worse of than you are now.
The spring should be in the position indicated below:
wow. that really sucks. there is no way I can get that spring back that far.
i'm taking it into the local bike shop.
Quote:there is no way I can get that spring back that far.
The springs in derailleurs are pretty strong, you will need some needle nose pliers, or something similar to get hold of it. How did it come off in the first place?
In any case, if the worst comes to the worst, the Tourney is line-up is one of Shimano's least expensive and should you need to buy one, a whole new front derailleur mechanism should cost no more than $10.00.
You could try making a loop out of strong string and pulling the spring into place. Or bend some stiff wire into a hook shape to pull with. Have a good look at the place where the spring goes and check that there is nothing missing.(such as a washer or retaining clip?)
I have never known a spring come off before.
(06-02-2010, 10:52 PM)xerxes Wrote:  I can't find a decent picture, but I'm fairly certain I'm right, if I'm not it won't do any harm and you'll be no worse of than you are now.
Hi Xerxes,
I'm having the same problem with my spring.
But, unfortunately I cannot see the image of CORRECT position, that you've posted.
Could you please share this image with me? This would help me as a reference image, to repair my spring.
You can email me this image: dusanersaurabh@gmail.com
Hello All,
I faced a similar issue with my Bicycle.
The front gears weren't shifting at all and I could see a spring dislocated near the front derailleur.
Attached are the photos of dislocated spring, And expected (Correct) position of that spring.
The actual position of this hook shaped spring is to its right top corner, where a small slot is available to hold it. ( Images attached)
I pulled the spring back to its position using a scrap brake wire. You can use pliers or hard metal wire.
After putting it in place, I pressed the hook to close it, so it won't fall off easily, the next time.
Hope this helps you all.
Cheers,
Saurabh
(07-12-2020, 05:50 AM)Saurabh Wrote:  After putting it in place, I pressed the hook to close it, so it won't fall off easily, the next time.
I believe that there should be "C" clip/"circlip" on the end of that pin where you connected the end of the spring just as there is on the pin were the spring coil is mounted. It is not uncommon for this "outer" clip to become dislodged being located on the more exposed side of the derailleur mechanism than the "inner" clip, especially on mountain and cyclocross bikes.
Take care,
Jesper
The great thing about trikes
Today 10:32 AM
What was your first bicycle?
Yesterday 06:25 PM
Yesterday 06:22 PM
Effective Breathing Method I use to go u...
06-01-2025 11:50 PM
"There's been better times
06-01-2025 10:48 AM
06-01-2025 12:47 AM
First long distance ride..
05-31-2025 10:33 PM
Is anyone riding with music?
05-31-2025 10:12 PM
Great Giro
05-31-2025 09:57 PM
Rusty chain inspite of cleaning,lubing
05-31-2025 09:54 PM
no avatar 1. Criminal
no avatar 3. Flowrider
no avatar 5. rydabent
