Shimano chain master link [Solved]
Hi. I have Shimano HG601 chain 11-speed and I want to add the master link to it.
Watched some videos but I have to be 100% sure, that is why I hereby present my brief plan:
1. there is a black link in the chain
2. I use the chain tool to push that black pin out
3. then I add the master link
4. finish up with using the special tongs to press that master link into the chain
Does this look like a green light?
close enough, you do not need the special pliars. connect on the bottom and give a quik tug by grabbing the chain on each side of the new link. Sometimes you may need the special pliars to remove it, but even then pinching the outer plates together and sliding works most of the time. If you have connected the chain before with a shimano break off the tab pin. do not break at that spot, leave it and go to a normal link for your break. do it so you end up with to inner links as the outer plates make up the quik link.
(09-02-2019, 12:23 AM)Painkiller Wrote:  close enough, you do not need the special pliars. connect on the bottom and give a quik tug by grabbing the chain on each side of the new link. Sometimes you may need the special pliars to remove it, but even then pinching the outer plates together and sliding works most of the time. If you have connected the chain before with a shimano break off the tab pin. do not break at that spot, leave it and go to a normal link for your break. do it so you end up with to inner links as the outer plates make up the quik link.
I never thanked you for these tips, so here it goes - thanks! I have since done two other similar "chain operations", not on my bikes, and all good with those too. This year has given me more time to learn about bike repairs and there is some good information here that helps in the process.
13,957
08-09-2017, 02:19 PM
Last Post: Desmond
15,675
12-04-2015, 09:41 PM
Last Post: GeorgeET
15,160
06-30-2015, 02:49 PM
SpeedBikeNut32
13,460
01-20-2015, 10:02 PM
Last Post: SpeedBikeNut32
17,696
01-13-2015, 05:28 AM
Last Post: benj
16,529
08-26-2012, 11:47 PM
Last Post: Bill
Call of nature while riding?
Today 06:18 PM
Rogue dinosaur and wall-riding geezer...
Today 03:13 PM
How new adventures begin..
Today 03:02 PM
Beautiful bikes
Today 02:56 PM
What size bike should I get?
Yesterday 05:14 PM
Yesterday 05:09 PM
Are carbon frames fragile?
Yesterday 09:03 AM
Yesterday 04:06 AM
Yesterday 03:52 AM
Bells as anti-theft devices
07-31-2026 10:49 PM
no avatar 2. Mr. Beanz
no avatar 4. rydabent
