Crank removal
A friend wrote me and wants to know what spindle he might have on his Schwinn Recumbent Bike model 223. He wants to replace the crank arm but is not sure whether it is square, isis or? He needs to know which removal tool to buy. Anybody know this or can he visually just look and see? Thanks.
Bud
A picture will tell.
The plastic cap on the crank needs to be removed, followed by the bolt or nut underneath.
Square, ISIS, Octalink are generally removable with the same tool. It is very important to make sure the outer part of the tool is completely threaded in before screwing in the inner part which pushes the crank off the spindle.
A Google search for "Schwinn 223 crank" yields this page: http://www.fitnessrepairparts.com/equipment/Select/7211/Schwinn/223, showing that it is a recumbent exercise bike with a square taper crank arm and hex bolt. Price for 2 OEM cranks is $30. As the cranks seem to have a curve outward it would be best to replace with original equipment. Your friend might try a local shop that sells Schwinn equipment.
(01-08-2015, 03:26 PM)cny-man Wrote:  A Google search for "Schwinn 223 crank" yields this page: http://www.fitnessrepairparts.com/equipment/Select/7211/Schwinn/223, showing that it is a recumbent exercise bike with a square taper crank arm and hex bolt. Price for 2 OEM cranks is $30. As the cranks seem to have a curve outward it would be best to replace with original equipment. Your friend might try a local shop that sells Schwinn equipment.
Thanks for the quick replies. I'll send them on and I think that should get him going. He was thinking of getting a Park tool for the square crank and the infromation about the crank arm curve will be good to know too.
Bud
1. If you removing the right side crank arm, lift the chain off the chainring and rest it on the bottom bracket shell.
2. Remove the dust cover (cap covering the crank bolt). The tool you need depends on the variety of cap. Some of them will require an allen wrench, screw driver or, in this case, a Quarter does the job. Be careful because most of the covers are pretty flimsy. If you don't have one, its not really an issue, just maybe rub a little great on the crank bolt to keep it from rusting, if it is rustable.
3. Remove the nut or bolt from the crank arm! Remember to do this, I'm an idiot and forgot to do this one time and spent a few hard minutes wrenching the crank puller like crazy until I realized I was an idiot and hadn't removed the crank bolt. Most bolts are 14mm, some are 15mm or 16mm and some are allen head. Unscrew it in the normal direction and check the inside of the crank for a washer and remove it, some have it, some don't.
4. Check to make sure you have the right size crank puller. Crank arms secured by nuts require one type, bolts another and then you throw those crazy Italians (Campy) in the mix and you need another one. Just make sure it seems to go together correctly or it could result in an epic fail.
5. Lube up the spindle and mating area (i.e. where the crank pull screws into the crank) Get you mind out of the gutter.
6. Unscrew the center portion of the tool out as far as it will go, the thread the out part of the tool into the crank arm, make sure it goes in all the way and then slightly tighten it with a wrench. I was a little lazy on this part in the video, but its important if you don't want to rip out any of the threads you need to get the tool in as far as it will go.
7. Tighten the inner part of the tool into the part screwed into the crank until the crank pops of, sometimes you have to crank like hell, if you can postition the wrench arm and the crank so you can squeeze them together to get some leverage, or put a pipe over the end of the wrench for extra leverage. (If you have a pipe laying around)
8. Pull the crank arm off and remove the tool, then repeat on the opposite side!
69,453
08-25-2025, 06:12 PM
Last Post: eugeneh
13,525
08-14-2022, 07:32 AM
Last Post: ichitan
39,841
07-19-2021, 12:00 AM
Last Post: rbx
6,789
02-27-2021, 07:52 PM
Last Post: rob keith
14,271
08-09-2017, 02:19 PM
Last Post: Desmond
39,921
11-02-2016, 04:48 AM
Last Post: ebgt
17,484
02-13-2015, 01:49 PM
