Newb needs help with Haro Backtrail X2
I was recently given a haro backtrail x2 and a lot of the parts are old and rusted so i want to change most of the parts. Its going to be a gift for my little brothers birthday so i only have a couple weeks to get it done(beginning of sept.) Unfortunately im not 100% sure of what im doing. As far as taking things apart and putting them together i think i can figure that out but im having a hard time figuring out what parts to buy. I THINK i know what i need but i dont want to order parts and find out im wrong. He rides in the woods for the most part, jumps some stairs and likes to ride fast so i dont want the cheapest part but certainly not most expensive. If anybody could give me some suggestions on what i need and what to buy that would be great. I can post more pics if yall want. I also put a link for the stock bike info. Thanks!!!
http://www.bikepedia.com/quickbike/BikeSpecs.aspx?year=2000&brand=Haro&model=Backtrail+X2
Any help would be great
There is simply no way for us to give you advice without knowing what problems you want to fix on the bike. that photo does not tell us if you have a bad Bottom Bracket, a loose crank, or any other problems. Taking things apart and putting them back together is pointless if you don't do it properly, but how to do so is not best done on a forum thread. This site has videos to help, but also Google what you want to do and look especially at results from parktool.com and sheldonbrown.com. No idea if there's a BMX specific site that might help.
Least expensive solution: purchase a new bike for your brother. And the only one which will meet any September (or October) 2014 deadline.
Ist guess at what you need:
brake cable
chain - did you measure stretch?
rear cog
tool to remove rear cog
possibly crank set - did you use the proper tool to pull them off?
tools to remove bottom bracket
tools to install new bottom bracket (maybe the same, or might not)
tires
tubes
rim tape
wheel bearings, possibly new cones (cheapest to get axle assemblies).
cone wrench of the correct size
headset bearings
15mm wrench to remove pedals
pedal bearings (or new pedals).
water resistant grease (I use boat trailer wheel bearing grease).
(08-24-2014, 10:55 AM)cny-man Wrote:  There is simply no way for us to give you advice without knowing what problems you want to fix on the bike. that photo does not tell us if you have a bad Bottom Bracket, a loose crank, or any other problems. Taking things apart and putting them back together is pointless if you don't do it properly, but how to do so is not best done on a forum thread. This site has videos to help, but also Google what you want to do and look especially at results from parktool.com and sheldonbrown.com. No idea if there's a BMX specific site that might help.
Thanks for the pages i will be checking them out shortly. As far as what i want to fix, everything except the frame, forks, handlebars, and seat/seatpost. The bike is about 10 yrs old and all stock so i feel like a lot of the parts need to go, i just dont really know what to buy or how to make sure im buying parts that will fit the bike and eachother. I had a friend of a friends who was supposed to come look at and teach me a little bit but he never came through so the internet is all i have now.
(08-24-2014, 12:25 PM)nfmisso Wrote:  Least expensive solution: purchase a new bike for your brother. And the only one which will meet any September (or October) 2014 deadline.
brake cable
rear cog
tires
tubes
rim tape
headset bearings
Ive made the decision to buy him a new bike and to make this my project bike to give me more time to work on it. Im pretty sure everything you mentioned needs to be replaced and i plan on replacing majority of stuff on the bike. Just going to leave the frame, forks, handlebars and seat the way it is. And no i didnt measure chain stretch, what do you mean? This is all new to me, i rode when i was younger but never got to a point where upgrading my bike was necessary. Most i ever did was change tires and patch tubes.
For me anyway, and your new perspective on the refurb. On 90% of the bikes I refurb and the prices I command. I do not worry about chain stretch. I replace all key drivetrain components. Just buy a new chain and freewheel, crankset @ your choice if worn badly. inspect and service all bearings, spindles, new grips, pads, cables/housing tubes/tires, peddles, where apply. Fluff and buff the rest!
(08-24-2014, 02:45 PM)Jalaska Wrote:  ...... didnt measure chain stretch, what do you mean? ......
Chains stretch with use; bicycle chains with over 1/16" stretch over 12" should be replaced before they start wearing the cogs at the rear. Over 1/8" stretch over 12" means the cogs/freewheel/cassette at the rear needs to be replaced, and the chain ring at the front should be very closely inspected, and probably replaced.
yea I can agree with you for the most part, but I liken it to replacing two car tires @ a time, thats all you end up doing ever so often. I choose to replace "all" key components and the crankset as needed.
suitable rear clusters and chains are chump change in my book, but really make for good resale, not to mention plain durability in its own right.
(08-24-2014, 03:01 PM)painkiller Wrote:  I replace all key drivetrain components. Just buy a new chain and freewheel, crankset @ your choice if worn badly.
How do i know what kind of freewheel and crankset to buy? You didnt mention this but how do i know if i need a new bottom bracket and how do i know what to get? Is there any way you (or anybody) could recommend some parts that are compatible with eachother?
ok soo i take it you are a bit low budget so let me help..this is my wheel house..whin you spin the freewheel does it click spin nicely ..it probably does, if you hear a sandy noise.wgile spinning the freewheel ..you can spray it with pb blaster and try oiling it again ...oil and spun till it sounds good..the 3pc is an "american sealed bottom bracket..stick your thumb in the hole of the crank berring and put pressure as you spin the berring, if you dont feel any binds or sandy type grinding you arr all good..if it binds at all, or sounds crappy take a flat head and a hammer pop the berring cup and all out. you can pop the seal off of the berring with a small flat head by carefully prying it up..to expose the berrings. douch the berrings out with wd 40 tiill all the grease is gone..blow em out let em dry repack em with grease, pop the seal back on..if the berrings are better use em if not buy a "american sealed bottom bracket" for 19mm spindle. its like maybe 30 on ebay..check the wheel nerrings, remove the axles and regrease the berrings and re install the axles..
get a new chain..get one at bennys for like 4 bucks..1 to 3 speed chain..a chain is just a chain dont go spend 30bucks on a chain, get a link removal tool..or if you are handy..when you install the crank, loosen the rear wheel..thread the chair over the rear cog and over the front chainwheel, till the links look like they would meet if you pulled a link out and replaced it with a master, remove said link, using a removal tool or a grinder grind the link pin down till its flush with the face of the link, and just pop it off with a flat head and a hamner and install new link..your headset is a 1 1/8 headset threadless..before you remove it just wpin the front end around and listen for any crap noises..likr dirt in the berrings..pull the front end off take berrings out clean out and regrease, check racers for wear, if they look good pot the berrings back in the way they came out..there is a right way and a wrong way to install these particular berrings..but if you want to replace thrm buy an, a headset headset it eill come with cups and berrings..just install em.
brake lines they sell a kit in walmart, like 6 bucks comes with front and back, some have gear cables..now the 990 brakes are easy to set up if you know how to tension them, use a wrench and i think its either a 5 or 6mm alan key, you will see a little plastic cap on the top of both brake arms, takeyour alan key and losten the alan key ..the arm will probably lose tension and park itself up on the rim..once losened take your wrench and turn the plastic cap on one arm until the arm pulls itself away from the wheel hold the wrenches position and lock down the alan bolt, repeat process for next side, if you need new pads get ones made for"990 brakes"..to clean the frame try superfine steel wool and chrome polish, works wonders..if you wanna order a new crank, which i doubt you need. any 3pc with an american bb kit will do..if the chain ring aint bent use it if it is get a new one its probably a 44t .hope this info helps,
oh and your freewheel is a 16t 4prong..meaning it takes a 4prong freewheel removal tool..usually any free wheel tool that fits odyssey freewheels will fit that..if you wanted to replace it..and you can pick up the superfine steel whool and chrome polish at walmart.
oh if you manage to pop the crank berrings out ..which is easy just use a flat head and a hammer position the flat head through the berring hole to the opposite. betting and try to hit it on the furthest part of the cup on the inside..and to put a new one or the old ones back in just position the cup of the berring in the crank hole get a block of wood that fits over the entire size of the berring cup and all and hit the wood evenly till the berring pops into the crank hole..no special tool needed
Do you have any idea how much of a pain it is for a person needing assistance to wade through posts with multiple typos, misspellings, and no punctuation?
yea, i apologise for that..it is a bit of a horror show to read, didnt realize how bad it was till it posted..oops..but most of what i said made sense, right?
#17
(08-25-2014, 11:00 AM)tourgee07 Wrote:  yea, i apologise for that..it is a bit of a horror show to read, didnt realize how bad it was till it posted..oops..but most of what i said made sense, right?
You do know that you can edit your entry ayer you post, right?
#18
(08-24-2014, 09:56 PM)tourgee07 Wrote:  ok soo i take it you are a bit low budget
Budget is not a problem but i dont need the best of the best parts, just pretty good. For example, I was looking at cranks and prices were about $50-$450. Id be fine with one in the $100 range. I would rather buy new parts than leave some of these on with how old they are(bad experiences with old bikes falling apart on me). Ive finally had some time to do some research and with everything you wrote ive got a better idea of whats going on. I think i just need to look at more parts and figure out what i want at this point. Im going to order everything and tools for the bb and freewheel. Thanks for everything you wrote, it wasnt too hard to read lol and thanks for the tip on cleaning the frame up. That i can do easily
#19
Don't knock old parts because they're old; much of the older stuff is better than what is available today. You do have to know how to tell the difference. For example, my primary commuting bicycle is a SR Sierra sport from 1982 - I purchased the frame and fork off eBay. The hubs are Suzue cartridge bearing from the mid 1980's. The rims are current Sun CR18, spokes Wheelsmith SS14, Sunlite BB, Shimano A050 crankset, MKS Lambda pedals, Avid V-brakes, Tektro levers, Shimano derailleurs, SRAM MRX gripshift for the rear and a Shimano lever for the front.
Another example, in my opinion, and many other people's also, the best Trek 900 series "mountain bikes" were the 1993 models and earlier. 1993 and earlier were lugged and brazed, 1994 and latter were TIG welded.
#20
I think the newest bike in my stable is a 97' thru 1989.I would not trade them for anything newer.
Exclamation
3,120
09-25-2024, 07:01 PM
Last Post: Jesper
Yesterday 04:29 PM
Yesterday 12:45 PM
How new adventures begin..
Yesterday 12:31 PM
11-27-2026 05:27 AM
11-26-2026 11:36 PM
11-26-2026 07:57 PM
11-26-2026 11:14 AM
Rhoades Car (4 Wheel bicycle)
11-26-2026 10:55 AM
11-24-2026 02:13 PM
11-24-2026 05:28 AM
no avatar 3. SPINMAN
