06-27-2011, 04:54 PM
I have been "installing" my bike tubes correctly each time to the letter. However, each time the tube tears at the tube-stem junction. I have taken the suspect wheel to a shop, the rim-tape has been reseated and the tread-lip has no damage.
I have done an on-ride tube replacement and it went flat at the same spot. It is the second time inside of one hour. This is the sixth time this month it has happened.
After using a plastic tire-lever on the wheel at home, I find the tube has for some reason folded-in on itself next to the tube-stem junction.
Before I fully inflated the tube inside the rim (with the tread-lip on both sides in the rim as they should be), I made sure it was inflated just enough for proper seating.
Even though I live in a desert; the tube, tread and rim-tape had more than enough moisture in them. Dirt was not even as issue. The spokes are also NOT poking through and are properly trued.
If this little tid-bit matters, I am using the right size tube.
QTubes, Schrader Valve: 26 x 1.9 - 2.125
I am thinking the tread could be replaced or the shop I went to has a bad batch of tubes. I did not see any punctures at any point in the tread.
Suggestions?
Suggestions?
Don't. Stop. Pedaling!
