First real project
So I have started the process to build a MTB from the frame up as a side project from second handish parts. Mainly because I want to learn and I love tinkering with stuff.
I have a great fork and an amazing frame. I know for a fact I need to have a headset installed but in I'm just not sure how to measure them to make sure they fit.
Just a few questions, and I apologize if these have already been answered I did not see anything in my searches.
1. Am I correct in thinking that the inner diameter of the crown barring needs to be super snug on the steerer tube?
2. What numbers are important when fitting a headset? (what should I be looking for or not worrying about number wise )
Thanks in advance,
Ryan
(04-07-2011, 10:50 PM)rpalmertree Wrote:  ...<snip>...
2. What numbers are important when fitting a headset? (wht should I be looking for or not worrying about number wise )
...<snip>...
Hi Ryan;
First; do you have a threaded or threadless headset?
If threadless:
1. no; the bearings should be very loose on the head tube - loose balls even if you have the patience to install them - you can fit more balls without the retainer, thus resulting in significantly stiffer headset. The balls (with or without a retainer) end up have angular contact between two surfaces.
[Image: k_a2_1_e.gif]
The image above shows a commercial ball bearing (aka sealed bearing as used in higher end hubs and cranksets). In the heads set, both the inner and outer races have a single land - they are often replaceable, and always hard steel alloy.
2. decide on loose balls, or balls in a retainer.
If you have a threadless headset things are a bit different.
http://www.sheldonbrown.com/headsets.html
Hey Nigel, thanks for the response!
The headset needs to be pressed in so threadless. I think the BBB said something like .1 to .25 is acceptable tolerances for a press fit.
So if my head tube was 33.4mm I would need to find a headset that was around 33.3mm - 33.1mm?
I'll checkout what Sheldon says today thanks for link!
Thanks,
Ryan
...<snip>...
Hi Ryan;
If threaded: oops !!!!!
sorry about that, should have gone to bed instead of responding.
21,811
11-30-2023, 10:33 AM
Last Post: Talha
13,380
01-09-2016, 01:19 AM
Last Post: Bill
22,927
01-01-2015, 05:20 PM
Last Post: elmore leonard
9,686
11-04-2013, 02:14 PM
Last Post: DaveM
7,153
06-23-2013, 11:20 PM
Last Post: FredS
82,931
07-09-2012, 01:06 AM
Last Post: jeracravo
13,990
02-21-2011, 01:56 PM
Last Post: eorta7
