meridian trike rear axle lubrication
good afternoon, i have spent the last week cleaning and changing parts on my old 2009 Schwinn Meridian Trike . The rear axle is in need of lubrication. Where is this done? do I just remove the axle retention nuts on each side and lube the bearings? What is a good brand of bearing grease available at Oreilleys? Thank you
Can't speak on Trike axles, but good grease depends on the application.
Normally, I use Lucas Xtra Heavy Duty grease. It's excellent, but has become difficult to acquire, and the formula seems to have changed a bit, and is thicker now. I've found that in high temperatures, Super Lube tends to be superior as a fast bearing grease.
If you have wet conditions, Xtra Heavy Duty or Marine Grease should do you well.
Red N Tacky is for special applications. I normally use it for threads and can't really recommend it for anything else.
Are you ready for some disassembly?
Use a wrench to carefully remove the axle retention nuts on each side of the axle
Inspect the Bearings. Apply a high-quality bicycle bearing grease to the bearings
Put everything back together
Today 05:49 AM
Today 03:33 AM
05-04-2024 01:49 PM
05-04-2024 12:32 PM
05-03-2024 02:34 AM
05-02-2024 12:40 PM
05-02-2024 12:37 PM
05-01-2024 10:57 PM
05-01-2024 10:51 PM
05-01-2024 09:57 PM
no avatar 5. Nutribun
