Tire size for rim question
Bought a Fulcrum Racing 5 wheelset and immediately put 622-28 Continental Ultragatorskin tires on. No problems with the tire installation, a bit of a struggle to get on but not unusual, and they look fine.
However recently went onto the Fulcrum website and downloaded their owners manual pdf. Discovered that they recommend 23 - 25 mm tires for the rims. The rim is rated ETRTO size: 622x15C. (This size rim in say Mavic Kysrium elite is compatible with 19-28mm diameter tires.)
So question - what is likely to happen if I leave the the 28 tires on the rims? They seem to fit ok. Seem tight to the rim. Anyone?
I will admit that I am not much of a pro at this , but they recommend 23mm to 25mm for the wheel. You put on 28mm. If it is tight and supposedly bigger then it should be fine. Although I really have not got that far into metric sizes for tires it does sound ok. Here is a little link that may shed some light on tires for you, I use it myself. http://www.sheldonbrown.com/tires.html
Hm, it might work out. The probability for the tyre to be stripped off the wheel when cornering fast is a bit higher than with the recommended sizes. There is probably a margin though, they usually give quite conservative estimates there (liability etc.). You went with a width that is 12% larger than recommended, keep that in mind.
Hi Cate;
Scroll down to the chart at the bottom of this page:
http://www.sheldonbrown.com/tire-sizing.html
I do not think that you'll have any issues.
14,284
01-08-2015, 12:09 PM
Last Post: 1FJEF
6,724
03-17-2014, 04:16 AM
Last Post: donna
27,667
09-30-2012, 01:53 AM
Last Post: Bill
11,125
03-26-2011, 02:48 PM
Last Post: nameused
13,898
03-19-2011, 12:07 PM
Last Post: Tim M
8,983
06-25-2009, 08:20 PM
Last Post: Caroline212
Today 12:50 AM
Yesterday 01:49 PM
Yesterday 12:32 PM
05-03-2024 12:13 PM
05-03-2024 02:34 AM
05-02-2024 12:40 PM
05-02-2024 12:37 PM
05-01-2024 10:57 PM
05-01-2024 10:51 PM
05-01-2024 09:57 PM
no avatar 5. TrailJoe
