Disc brakes rubbing
I ride a 2009 trek road bike with disc brakes and once and awhile the rear rotor will rub initially on my ride then after using brakes i'll lose the sound is this a normal thing? While at ubi class i installed new cables and adjusted pads rotor clean etc.
I would take it back to the shop and have them to look at it.Is the disc lose? or it could be the wheel is a little out of true. Hope this helps.
(01-11-2010, 04:32 PM)KDC1956 Wrote:  I would take it back to the shop and have them to look at it.Is the disc lose? or it could be the wheel is a little out of true. Hope this helps.
the funny thing is once im rolling and have applied rears the contact sound disappears. i recently attended a ubi class in portland oregon and in the class we went completely through our bikes so running gear is ok rotor torqued etc
So when you put it on your stand and spin the wheel does it rub then? If you eye it can you see where its hitting? You might just need to back out the caliper 1/8 of a turn.
Also one thing I've experienced. Once the bike is on the ground, completely loosen the quick release then re-tighten it. I have had a few times where the wheel was not completely in the dropouts when it was put on the bike. The weight of the bike will set the wheel correctly, if that is an issue.
Hopefully one of these things will solve your issue.
Could it be something in the Hydraulics, like a small foreign object tiny pebble etc? I do have a bike which I have not yet got to this winter but soon hopefully that has disc brakes. There is also an article here which may shed a little light but no guarantee...
http://www.parktool.com/repair/readhowto.asp?id=125
thanks
(01-15-2010, 10:41 AM)Jordan300 Wrote:  So when you put it on your stand and spin the wheel does it rub then? If you eye it can you see where its hitting? You might just need to back out the caliper 1/8 of a turn.
you know the second item you mentioned
i believe is the issue went through that yesterday thanks for the help
Awesome, Glad I could help.
Today 06:59 AM
Yesterday 08:55 PM
Yesterday 08:09 PM
Yesterday 07:32 PM
Yesterday 07:07 PM
10-16-2026 01:27 AM
