Brake lever spring
Hello,
I was trying to put in a new brake wire on a mountain bike Next Px 4.0 24".
Unfortunately I disassembled the brake lever (though it was not required to obviously).
Anyways now that I try to reassemble it, the brake lever spring mechanism is not working. The brake lever is of 'Sun run' brand (Chinese company).
Since I dont have a lot of time on my hand, I am thinking about getting a new brake lever. How do I know if it would fit on the bike's metal handle ?
I am looking to buy a cheap brake lever ? Any suggestions ?
Thanks y'all.
Measure the handlebar diameter. Most brake levers should work, sometimes you need shims, but they should come with the levers. For one of my bikes my LBS had a pair of used Avid break levers lying around that I could have for... dunno... a fiver or so. Just make sure that you get a lever for the style of brkaes you have, V-brakes (linear pull) and Cantilever breaks need different levers!
Thanks for your reply. It says that Px 4.0 has a V-brake installed.
I found this on amazon. http://amzn.com/B001GSMJF4
It doesnt mention for what type of brake system it is for (V or cantilever). Any ideas?
(09-24-2013, 11:03 AM)sab456 Wrote:  Thanks for your reply. It says that Px 4.0 has a V-brake installed.
That one will not work; it is "short pull". V-brakes (and most mechanical disc brakes) need "long pull" aka linear.
This one will work:
http://www.amazon.com/Tektro-319A-BMX-Linear-Brake/dp/B000V6TYRI/
(09-24-2013, 11:43 AM)nfmisso Wrote:  That one will not work; it is "short pull". V-brakes (and most mechanical disc brakes) need "long pull" aka linear.
This one will work:
Hello
Can V-brakes be visually differentiated from Cantilever ? I am asking this as there is an old mountain bike lying around whose bike lever I could salvage and install on the Next PX 4.0.
Easily; take a look:
http://www.personal.psu.edu/bjd5054/blogs/flat_tyre/BRAKES.JPG
This one will work:
How would i know if this product would fit on a 24mm diameter bike metal bar ?
24mm OD is standard for most bars, except drop bars, it will fit. At worst, you'll need a shim.
Thanks a lot to all of you guys for helping out. I was able to succesfully install a new brake lever on the bike. Brake system works great so far !
23,208
12-23-2011, 09:42 AM
Last Post: Dale
Today 04:46 PM
Today 03:00 PM
Derailleur
Yesterday 12:43 PM
Yesterday 12:40 PM
Yesterday 06:33 AM
Yesterday 06:29 AM
Yesterday 06:25 AM
11-01-2026 09:48 PM
11-01-2026 12:24 PM
How new adventures begin..
10-30-2026 05:07 AM
