Master link in Shimano chain
I want to install a master link in my chain. The local bicycle shop advised that a master link does not work well on a Shimano chain. Is that correct, or will it work?
Ask your LBS why?
I have used various master links on both 8 and 10 speed with no problems.
I favour KMC ones as I had a problem with a Sram that I couldn't re-fit after removal for cleaning.
None have given me a problem while cycling in a few thousand miles.
Just stay away from Shimano's quick links. They were a failure (and are not made anymore).
(06-13-2010, 02:12 PM)Joe_W Wrote:  Just stay away from Shimano's quick links. They were a failure (and are not made anymore).
That's a new one on me and have been using Shimano chains for 16 years.
I didn't know Shimano ever made "quicklinks".
You learn something new every day?
Did a Google and found:-
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Dura-Ace/SI_0074A_001/SI-0074A-001_En_v1_m56577569830655402.pdf
Can see why they failed.
And while Googling came across a post saying that some Sram links can't be re-used a second time ??
I recently bought an SRAM chain which came with a "PowerLink", I opted to leave it out. If you have a chain tool it only takes a couple of minutes to break an re-connect a chain and I carry one in my tool kit. I don't see a huge benefit in using one, whereas in using one one, there's the possibility that there's a weak link in your chain.
(06-13-2010, 08:25 PM)xerxes Wrote:  I recently bought an SRAM chain which came with a "PowerLink", I opted to leave it out. If you have a chain tool it only takes a couple of minutes to break an re-connect a chain and I carry one in my tool kit. I don't see a huge benefit in using one, whereas in using one one, there's the possibility that there's a weak link in your chain.
If you re-use rivet pins in a Shimano chain it can cause damage to the pin. That's why you should use the special pin or a quick link.
Having said that I have re-used the pins without any problems but now use Quicklinks.
See Park Tool (Procedure for Shimano chain!) for explanation:-
http://www.parktool.com/repair/readhowto.asp?id=25
Quote:Having said that I have re-used the pins without any problems but now use Quicklinks.
I've never once had a problem with re-using pins in thousands of on and off road miles, but I've never used a Quicklink, so thought I'd stick to what I know. Smile
My Cannondale 6 series came with a KMC 10-speed chain with KMC's reusable link installed. This was my first experience with KMC and resuable links. Now I clean my chain, off the bike, regularly. I was so impressed with the KMC link that I installed one in my Dura Ace chain and have had no problems--just an impeccably clean and freshly lubed chain, all the time. I am sold on KMC.
6,476
10-26-2020, 08:28 PM
Last Post: stanS
14,305
08-09-2017, 02:19 PM
Last Post: Desmond
15,904
12-04-2015, 09:41 PM
Last Post: GeorgeET
15,439
06-30-2015, 02:49 PM
SpeedBikeNut32
13,729
01-20-2015, 10:02 PM
Last Post: SpeedBikeNut32
18,034
01-13-2015, 05:28 AM
Last Post: benj
16,807
08-26-2012, 11:47 PM
Last Post: Bill
Yesterday 11:22 PM
11-17-2026 05:23 PM
11-16-2026 07:09 PM
11-16-2026 07:01 PM
11-16-2026 06:56 PM
11-16-2026 06:54 PM
11-16-2026 05:29 PM
