Saddle Height
When I got back into cycling about five years ago, I went to a bike shop to buy a bike. The mechanic instructed me about the saddle height. While sitting on the saddle, hips level, my heels should rest on the pedals at the very bottom, and my legs should be straight, in line with the seat tube. I found this works well. Of course, I don't ride with my heels on the pedals.
Recently, I was looking online at the manual for the Electra cruiser I bought this year. It instructs the rider to have the seat at a level where both feet can just about sit flat on the pavement. This feels awfully low to me, and it seems to be a less efficient way for riding.
There are a lot of bikes in Florida and I noticed most riders - often on mountain bikes - have their saddles at the lowest point, so their knees are up in the air.
I was wondering why this 'feet on the ground' applies to cruisers and not other bikes.
(07-01-2020, 07:41 AM)CharleyFarley Wrote:  When I got back into cycling about five years ago, I went to a bike shop to buy a bike. The mechanic instructed me about the saddle height. While sitting on the saddle, hips level, my heels should rest on the pedals at the very bottom, and my legs should be straight, in line with the seat tube. I found this works well. Of course, I don't ride with my heels on the pedals.
Hey Charley,
I'm more inclined to go with the first recommendation. I really only ride road bikes, so in that riding posture I attempt to have my leg when at the bottom of the pedal stroke not quite straight, knee slightly bent. If I did the heel thing and straight leg set-up, l don't know if it would give me the same position due to the use if my racing shoes, but it would probably be close. When I ride on my old Raleigh 3 speed in an upright posture l still have the saddle height about the same, but it's the saddle position that l change (angle, and front to rear). The higher your knee comes up on a stroke, the less power you produce. Easy to demonstrate just by doing a knee bend from standing, even more so on one leg. The lower you go, the harder it is to straighten up. The only thing you really need to take into consideration other than having too much knee bend is comfort. If you are feeling pain in the knee or ankle you may have to adjust the saddle height and/or front to rear position for comfort. I see people all the time riding with their knees coming up far too high, not really sure what to make of it, but they could never ride hard and long in that manner with any real level of efficiency. You definitely should not be "reaching" with your toes for the pedal either. That generally creates ankle/foot problems. Of course, to each his own.
Take care,
Jesper
(07-01-2020, 07:09 PM)Jesper Wrote:  [quote='CharleyFarley' pid='38961' dateline='1593603714']
Quote:When I ride on my old Raleigh 3 speed in an upright posture l still have the saddle height about the same, but it's the saddle position that l change (angle, and front to rear).
I had two bikes on which I put 2-bolt seat posts for fine adjustment. I have realized how critical the seat angle can be. The bike shop advised me to adjust it so the nose is level with the back. That seems to be a starting point but found I prefer a slight nose-up position on my fat bike. I know that wouldn't work on a road bike where you are bending lower.
Quote: The higher your knee comes up on a stroke, the less power you produce.
That's the way I see it. And that's why, when I lowered the saddle to Electra's way, I didn't like it. I've always been one to want to know the reasoning for any kind of advice, and Electra's doesn't make sense to me, unless it's a 'fashion before comfort' kind of thing. But who rides for fashion?
Quote:Easy to demonstrate just by doing a knee bend from standing, even more so on one leg. The lower you go, the harder it is to straighten up. The only thing you really need to take into consideration other than having too much knee bend is comfort. If you are feeling pain in the knee or ankle you may have to adjust the saddle height and/or front to rear position for comfort. I see people all the time riding with their knees coming up far too high, not really sure what to make of it, but they could never ride hard and long in that manner with any real level of efficiency. You definitely should not be "reaching" with your toes for the pedal either. That generally creates ankle/foot problems. Of course, to each his own.
I have wondered about all the cyclists I see with saddles as low as they'll go, if they are not aware that riding would be more efficient with a proper saddle height.
I know, as we age (I'm soon to be 74) that our joints don't work as well as they did when we were young, and we need to take care of such things by not over-stressing our joints. I don't want to do damage that would stop me from my daily rides.
Thanks for your input, Jesper.
All the best to you.
(07-01-2020, 07:41 AM)CharleyFarley Wrote:  .....have the seat at a level where both feet can just about sit flat on the pavement....
I forgot to add insight to this part of your query.
I believe that this "feet on the ground" stems from the general consensus that someone on a "cruiser" bike is travelling at a slower speed (thus, low physical stress), is not riding any great distance, in general, without having to make many stops (maybe a couple miles at most) and is subject to many stops (whether voluntary or involuntary); and thus, never really has to "dismount" or stand/lean while stopped. This makes cruising (l guess) more fun since you never do anything other than to put your feet on, or take them off the pedals; staying put on the saddle all the while. It makes me think of my sister who, upon buying her first motorcycle (Japanese "cafe" racer), had to lean the bike over during a stop because she could only touch on her tippytoes otherwise, thus having to "manhandle" the bike a bit. She could have bought a cruiser type of motorcycle and put her feet down at stops without leaning and sliding off the bike to be stable. I am the same way on my race bikes (l tend to ride a little bit larger frame than would be recommended), making starts/stops a wee bit more difficult than when l ride my smaller frame and can straddle the top tube without "testicle concerns"! Of course, while on a race bike l am much less inclined to stop ( even when l should, sorry!), and generally ride where there are not many, if any, stops required except at the end of the ride.
The bike shop that service my new-to-me Specialized Tarmac Elite saw that I could put my feet on the floor while on the seat and immediately recommended raising it. Made a big difference in performance and comfort.
(09-23-2020, 02:58 PM)Evan J Green Wrote:  The bike shop that service my new-to-me Specialized Tarmac Elite saw that I could put my feet on the floor while on the seat and immediately recommended raising it. Made a big difference in performance and comfort.
Oh yes, you gotta stretch those legs properly!
I often see guys on road bikes with saddle way too low & with the knee angle so wrong.
"Carbon is faster"
The heel on the pedal with leg straight method works fairly well for me. I also like my saddle ever so slightly tilted nose down. It is interesting how may people you see riding who look like a bear on a bicycle.
Justin Schultz
2020 Scott Scale 970
2021 Felt Breed 30
(10-07-2020, 07:29 PM)J_R_Schultz Wrote:  The heel on the pedal with leg straight method works fairly well for me. I also like my saddle ever so slightly tilted nose down. It is interesting how may people you see riding who look like a bear on a bicycle.
The same here, straight leg is a must.
I see some road cyclists who have their legs/knees "out" while pedalling ... bear mode indeed.
7,105
08-26-2019, 03:41 PM
Are carbon frames fragile?
Today 06:28 PM
Call of nature while riding?
Today 06:18 PM
Rogue dinosaur and wall-riding geezer...
Today 03:13 PM
How new adventures begin..
Today 03:02 PM
Beautiful bikes
Today 02:56 PM
What size bike should I get?
Yesterday 05:14 PM
Yesterday 05:09 PM
Yesterday 04:06 AM
Yesterday 03:52 AM
Bells as anti-theft devices
07-31-2026 10:49 PM
no avatar 2. Mr. Beanz
no avatar 4. rydabent
