Problem with Deore DX Shifter
[Image: IMG_20170205_162903.jpg]
[Image: IMG_20170303_103150.jpg]
I have a problem on my Front bicycle derailleur. I'm new to bike repair so I'm not sure of using the right terms. The chain is on the largest chainring in the front and when I use the small pusher on my shifter, I can hear a click but the chain doesn't move to a smaller chainring. I read online some advices and I removed the cover of my shifter, I put WD40 first, waited a long time, then put triflow, but it didn't fix the problem. In the shifter, I don't see any cable, I don't know where the cable is supposed to be.
Is there a way to repair it? If not, should I buy a new shifter? If yes, does it have to be a 7 speed shifter also? I'd prefer to buy on eBay, but I don't want to spend more than $25 (or else I would sell my bike for $50). Is it difficult to remove the old one and install a new one?
If you hear a click then the lack of movement may be in the cable and housing binding. you need to diconnect from the derailleur and pull the cable by hand and shift the shifter up and down to detect movement. if it moves replace the cable and housing. these shifters are known to have the grease solidify after a few years which causes the pawls in the mech not to work as intended. If this is the case then it is important to flush out the old grease first. these are much harder to bring back to life than the newer trigger style. Either way you need to remove them from the bike, dig out as much hardened grease as you can. Place them in a can and drench them with engine cleaner from the local auto store like autozone. scrub them with toothpicks and old tooth brushes, drench them again with the cleaner if you have too. Then power rinse them with the hottest water you can withstand, sprayer on the kitchen sink is good for this. then blow dry til dry. use a light silicone type lube, soak well. the put cable back in, pull by hand and test for function. DO NOT USE WD-40.
If this does not work, replacement is your only option. you have integrated shifter/lever combination which means you need to replace the levers and shifters if the fix did not work. you will need standard pull levers (not V-brake) of your choice.
yes you will need a 3x7 set of shifter pods and probably new grips. the shifters you need are
SHIMANO SL-M310 ALTUS RAPID FIRE 21 SPEED
No, it is not a $25 job. If you hate your bike so much that it is not worth it. Then sell it to someone for the $50 and make them happy. Then what? what do you do for a bike with $50. The early 90's bike you have now are some of the finest bikes that will ever be made and are well worth going thru to make good user's again. The bike you have could have easily cost $600 or more back in the day. A $600 bike today is junk compared to that. My newest bicycle is a 1997, my daily bike is a 1994 I refurbed a couple years ago to the tune of about $800, no regrets. Its the best. Its all in what you want, just be informed. I would like to see pics of your bike just for fun if you have the time. cheers
I will follow your advice.
To see pictures of my bike, click HERE
Thanks for the pics. Yep never seen one of those before. strange to have an alloy bike with Dx shifters like that. The other problem would be the shock,probably cannot get parts for it anymore. If it was cromo steel and rigid it would be a better bike to refurb. Try what i told you first, if it fails then even i would sell it off and start with something else. I just like the retro steelies to redo than waste my money on brand new bikes. good luck and let us know if you got them freed up or not
2,596
08-02-2021, 07:23 AM
Last Post: Blank.Toogii
3,770
04-21-2019, 10:41 PM
Last Post: peter bill
15,958
10-05-2017, 10:28 PM
Last Post: kazz
7,532
06-23-2017, 09:39 AM
Last Post: dude
9,323
03-01-2016, 04:47 AM
Last Post: dude
18,099
10-02-2013, 07:06 PM
Last Post: !TREK4ME!
23,859
02-21-2013, 07:28 AM
Last Post: Henry
Today 12:32 PM
Today 05:15 AM
Yesterday 12:13 PM
Yesterday 02:34 AM
05-02-2024 12:40 PM
05-02-2024 12:37 PM
05-01-2024 10:57 PM
05-01-2024 10:51 PM
05-01-2024 09:57 PM
Hardtail Party
05-01-2024 11:02 AM
no avatar 5. Frankly
