Trail Mountain Bike 4 sale/ CASH ONLY.
    I’m selling a Cannondale Trail MB with 29” wheels. The front of the bike is purple and the back of the bike is silver. I’m hoping to interest anyone from the New York area.
I’m hoping to sell the bike for about $850 but the price is negotiable.
https://forums.bikeride.com/forum-68.html
Post this in The Marketplace as well. Happy selling
(07-31-2024, 05:52 AM)Talha Wrote:  https://forums.bikeride.com/forum-68.html
Thanks! ☺️
Thanks! ☺️
I would add detailed, well lit, and in focus photos (10 photos allowed per each post) of components, tires, etc.
The bike looks fine, but if there are any dents, scratches, saddle scuffs/cuts/tears, etc. You should mention them and show photos which will allow a buyer to make an educated decision and save you from having to answer questions already covered with photos. Show both sides of the bike. Also, provide frame size, and give a bit better idea as to location since NYC, and Rochester are in NY, but quite far apart.
Thanks! ☺️
Thanks for your detailed advice. I’ll add more over the weekend.
So like I mentioned in the first post, I rode this bike about 8-10 times maximum. Which is why there is no damage found on this bike whatsoever, and I’m a pretty careful rider. The only reason which I considered selling this beauty is because a newbie like me failed to realize it has no speed. Frame height on this bike is between 16-17” bottom to top of the mid-bar. I live the Bronx and can travel to any of the other 4 New York cities without issues and including the Westchester area.
Attached Files Image(s)
(08-10-2024, 09:21 AM)Levitius83 Wrote:  So like I mentioned in the first post, I rode this bike about 8-10 times maximum. Which is why there is no damage found on this bike whatsoever, and I’m a pretty careful rider. The only reason which I considered selling this beauty is because a newbie like me failed to realize it has no speed. Frame height on this bike is between 16-17” bottom to top of the mid-bar. I live the Bronx and can travel to any of the other 4 New York cities without issues and including the Westchester area.
Thanks to the few who cared to respond. I’m surprised no one mentioned what I realized later on was best to change the middle crank to at least a 53T outter.
That front ring (outer?; looks like a single ring crank) depends on your smallest rear cog (and of course the bike's intended use). I doubt you need a 53t ring unless you want it for fast descents. 46t-50t if your small cog is 11t-12t (really depends on your strength; most cyclists cannot ride 53t/11t-12t as a regular gear). If you (or who ever buys it) has to do any severe climbing a big front ring might not be the best choice. Your bike gearing was designed for a certain range of use; it was not designed to be a fast road bike (something I would not ride as a commuter or anywhere a road or roadster would suffice. You might need 2 bikes if you want go fast and also ride rough trails. Possibly get a gravel type bike that will still be faster on roads, but still be able to traverse rougher terrain.
Plus, looks like you need to change the crank to fit a large ring. I would question if you test rode the bike since you would readily determined that it would not be geared for you use upon doing so. If you like the bike other than gearing then modify it. Rear derailleur needs to able able to handle the gear range should you get a bigger ring or you may not be able to shift onto largest rear cogs.
If your bike is still for sale then post it on craigslist. A local post will sell it quick if the price is reasonable. Year and model of the bike helps buyers. I doubt you can get even close to your asking price ($500?). Bikes like that are greatly overpriced when new and depreciate immediately by about 30% or more with one use.
That front ring (outer?; looks like a single ring crank) depends on your smallest rear cog (and of course the bike's intended use). I doubt you need a 53t ring unless you want it for fast descents. 46t-50t if your small cog is 11t-12t (really depends on your strength; most cyclists cannot ride 53t/11t-12t as a regular gear). If you (or who ever buys it) has to do any severe climbing a big front ring might not be the best choice. Your bike gearing was designed for a certain range of use; it was not designed to be a fast road bike (not something I would not ride it as a commuter or anywhere a road or roadster would suffice. You might need 2 bikes if you want go fast and also ride rough trails. Possibly get a gravel type bike that will still be faster on roads, but still be able to traverse rougher terrain.
If your bike is still for sale then post it on craigslist. A local post will sell it quick it the price is reasonable. Year and model of the bike helps buyers. I doubt you can get even close to your asking price ($500?). Bikes like that are greatly overpriced when new and depreciate immediately by about 30% or more with one use.
I thank you for your input but after brainstorming with my bike mechanic over the phone about what size front crank fits best, he helped me narrow it down to a 50T but we’ll definitely know for certain after I bring it to him in person next weekend.
I second Jake1 on cross posting this bike on Craigslist and may be FB marketplace? I used to goto Craigslist first whenever I was in the market for bicycle..
If your bike is still for sale then post it on craigslist. A local post will sell it quick it the price is reasonable. Year and model of the bike helps buyers. I doubt you can get even close to your asking price ($500?). Bikes like that are greatly overpriced when new and depreciate immediately by about 30% or more with one use.w
Sorry guys I completely forgot to let you guys know about the progress on upgrading my 12t Trail Bike. During the Summer, it took my very busy mechanic a month to realize after trying out a few crank sizes that the biggest size he would be able to fit on the bike frame properly is a 32t. Also he considered putting on some “MAXXIS RE-FUSE 700x28c” smooth skins. The reasonable upgrade cost was $250 with taxes included. So now my steel horse finally rides like her original worthy price of $1300. In conclusion, my Trail Bike is off the market.
1,909
08-06-2025, 09:54 AM
Last Post: Daniel Nathan
3,632
12-20-2023, 09:39 AM
Last Post: Mike T
Star
6,146
12-03-2020, 06:03 AM
