Stripped Crankarm
A few weeks ago I replaced the broken pedals on my mountain bike with cheap $8 plastic pedals from Wal-Mart. Yesterday I was riding the bike and all of a sudden my pedal fell off. Upon closer inspection, I found the pedal AND the hole where the pedal screws into the crank arm is both stripped. What can I do?
-Garrett, Boonville, MO
what type crank do you have? Can you post pics? I replace pedals and cranks when this occurs. they do make a pedal fix heli-coil thread repair for this but I am totally against using them. I may have a replacement for you but need to know what you have. I do sell some new and used parts from time to time and even give them away depending on what it is.
http://www.parktool.com/blog/repair-help/pedal-bushing-kit
To me this is shoddy craftsmanship, many bike shops will perform this task. By the time you go thru all this, and the crank is lowend anyway. you can buy a good used or new one and be dependable once again. The problem I have using this method is quite clear. The crank is worthless junk and if I bought a used bike and this was not revealed before buying it and it was an expensive crankset, I would be pissed to say the least. There is really not an easy way to catch this upon a quik inspection. Merely a practice to avoid and never start doing. But thats me, I never deviate from "equal to or better than" when it comes to quality repair and or upgrades.
HEY PK helicoil repairs and a stronger time sert (IIRC) work well in engine repair. Another better method is to weld the hole than re bore and re thread.
However cranks are comparatively inexpensive so replacement is preferred, and about as expensive..
How much does a new crank cost? Is it easy to replace?
I'm highly considering selling the bike. It's a cheap six-speed Huffy, but it's been well maintained. It has practically new tires and tubes, and a comfortable seat on it. Sadly, it has problems in first gear and the brakes are worn down to the metal basically. Then the crank issue.
But I also have a 1981 Free Spirit Pinnacle road bike that I want to restore to working condition. It works flawlessly, the only problem are the old steel rims won't accept the high pressure tires produced today, so when I install a tire it just blows off the rim and ruins the tube (and sometimes the tire.) I found some good rims that cost around $32-$33 at Niagara Bike, as well as some good tires and tubes that aren't all that expensive. There is nothing else wrong with the road bike except for the rims.
I believe the cheap pedal did it, as it wasn't stripped before - and the pedal is stripped on the same side as the crank.  I find it strange that the crank and the pedal are only stripped on one side, which makes it somewhat harder to get pictures. But I'll try go get pictures later.
As far as the huffy, I would call it a wash. Sell as is for what ever you can and put towards the other bike's wheels. The market is flooded with dept. store bikes so you would lose money in the deal if you repair it. Sorry. Look at craigslist and you will see what I mean. People have yards worth of them and they go pretty cheap. I never bother with them at all, just for that reason. Better off to find a deal on an upper end bike and spruce that up for yourself.
(06-06-2015, 02:51 PM)painkiller Wrote:  As far as the huffy, I would call it a wash. Sell as is for what ever you can and put towards the other bike's wheels. The market is flooded with dept. store bikes so you would lose money in the deal if you repair it. Sorry. Look at craigslist and you will see what I mean. People have yards worth of them and they go pretty cheap. I never bother with them at all, just for that reason. Better off to find a deal on an upper end bike and spruce that up for yourself.
I understand what you mean there. There are tons of bikes on Craigslist. But could I sell it with a stripped crank arm?
The Free Spirit was a good bike, but I haven't been able to ride it within three years due to the rims. Which is why i plan on fixing it
Advertise as (parts or Repair) $40 OBO. Here is an example of a flip to help add $$ to your pocket. 1993 Specialized rockhopper, bought for $75 (The asking price). I replaced the cables/housing ($15). grips (free). brake pads ($15). Cleaned and tuned it. I will sell it for $200 to $240. I expect about a $100 give or take a couple, in profit.
Then I will have extra $$ and do it again and again. That is all you have to do to work your up to more tools and better bikes.
[Image: 93full_zpsjtzuu0bp.jpg]
[Image: 93I_zps49nex6as.jpg]
[Image: 93II_zpsqmv5d8bj.jpg]
[Image: 93III_zpssmn7vgkf.jpg]
Even Though it is an old bike, if you do not skimp on quality and clean and shine every little piece and make sure it rolls out nice. It will sell. Compared to a new bicycle in the $240 range, this bike will sell its self.
You most likely cross threaded the new pedal stripping threads on both. If the Huffy has good wheels perhaps you can combine parts from both bikes and get one ridable one.
(06-06-2015, 04:29 PM)GeorgeET Wrote:  You most likely cross threaded the new pedal stripping threads on both. If the Huffy has good wheels perhaps you can combine parts from both bikes and get one ridable one.
The huffy has good wheels and tires, but the road bike is 27 x 1 1/4 and the huffy is 26 x 1.95. A considerable size difference, both height-wise and width-wise.
But how can I sell a bike without a right pedal and a stripped crank arm?
"But how can I sell a bike without a right pedal and a stripped crank arm?"
Like I said, there a zillion of these kind of bicycle's out there, along with people with whole front yards of them for sale. These bicycle guys need parts to take three bikes to make one. You need to post the bicycle as "For parts or repair" $40 or best offer.
and take what you can get. The bike would be a tough sell for $50 in good shape. It will cost you $30 or more to repair. Take a $10 or $20 offer and move on. There is nothing you can do to make the bike profitable to you. He could have a bike with good cranks but needs wheels, understand?
(06-06-2015, 06:48 PM)painkiller Wrote:  "But how can I sell a bike without a right pedal and a stripped crank arm?"
After hearing that it will cost $30+ to fix, I think I'm just going to sell it. I don't ride on the trail anyways, and when I did ride on the trail, the road bike sufficed just fine.
But I'm not going to sell it until I can fix the road bike and get it working reliably.
5,833
08-25-2020, 03:44 AM
Last Post: Jesper
21,863
05-06-2015, 01:38 AM
Last Post: eastman
19,110
10-22-2013, 12:26 PM
9,049
04-02-2013, 02:55 PM
Last Post: RBurrelli
9,714
06-14-2012, 09:43 PM
Last Post: FredS
27,162
06-16-2011, 07:53 AM
Last Post: Bill
Yesterday 02:13 PM
Yesterday 09:27 AM
Yesterday 09:22 AM
Yesterday 05:28 AM
11-23-2026 04:29 PM
11-23-2026 10:55 AM
11-23-2026 03:42 AM
11-23-2026 03:39 AM
11-22-2026 02:13 PM
11-21-2026 12:06 PM
no avatar 2. Sidewinder
no avatar 3. SPINMAN
