Are carbon frames fragile?
I keep seeing ppl post pictures of chips and cracks
Are they all that fragile? And if so why buy them?
Enlighten the old man
Since CF bikes are just reinforced plastic, the older they get the more fragile they will become, as the plastic hardens.
(05-04-2026, 02:23 AM)NaLya Wrote:  I keep seeing ppl post pictures of chips and cracks
Quick answer is no. Carbon fiber (CF) frames are not fragile, nor are they "plastic" as previously mentioned, but like anything there are higher and lower quality grades of materials used, as well as the quality of design and production.
When used properly for their intended purpose, and properly maintained and stored they are quite durable. It does not matter about the materials, everything degrades with age and use, just some quicker than others and it seems that CF frames are going to go to pot faster than steel, Ti, aluminum frames; but caution to those who think they can jump on a bike with 50+ year old wooden rims and expect no problems even if they look okay visually. I just saw a 1901 bike frame that initially used bamboo tubes in the frame (steel lugs), but the bamboo had been replaced with broomsticks. No idea why it was "rebuilt" with solid wood (bamboo damaged by age derioration, accident, etc.). Presently, the bike is rebuilt with bamboo again.
CF in general is quite simple; essentially only the fibers themselves which do not degrade, and a resin matrix ("glue") that binds the fibers. It is the resin that slowly degrades depending on its actual composition, other various factors. I have seen every type of bike frame material fail prematurely; usually do to poor materials, poor fabrication, and improper use.
That being said, CF frames are not designed for high speed impact damage, especially depending on where/how the frame is hit. A CF frame is designed to be quite strong, but only by design for a specific use. If a CF frame falls on its side and impacts a sharp or pointed edge it can damage the frame, especially if loaded/top heavy. Unfortunately, thin steel tubed frames (generally those with wall thicknesses well under 1.0mm) are susceptible to similar damage.
Chips are usually not related to the CF itself, but the protective/decorative finishes used to protect the frame (mininal impact, UV and other elemental exposure). The most insidious signs of CF frame failure are usually found within the material itself and internally to the frame: air pockets, delamination, micro-cracking. If you see an external crack you can be guanteed in most cases that that failure started long before that crack became apparent externally (barring an accident). In general and like bike helmets, if you have an accident you should dispose of the frame/helmet and get a new one.
Steel generally provides some sign of impending failure during usage wjereas CF tends to have catastrophic failure if not noticed during inspection. Unfortunately, the majority of damage is not able to be repaired like with a steel frame. I never recommend buying any used CF frame (especially mtb/gravel) that shows any signs of outward use/damage, and CF frames neing inspected 20 years after have shown signs of deterioration when "autopsied". Granted malers are improving building methods and the matrix. People will not being riding CF bikes made 20 years ago in another 20 years without knowing if they can hold up to normal use, whereas steel frames built 150 years ago are regularly still being used by those into classic bikes. Classic CF bikes will not be able to match that unless technology and materials improve.
The CF frames were initially designed as only being for professional use where the bikes are not used repetitively (often only used a couple times), and merely considered as throw away tools of the trade.
The reason they are now mass produced and sold to many who do not gain by their design advantage is simple: MONEY? The frames are generally overpriced by about 50% (comparable to the components that hang on them) considering how easy the majority are made once designs are developed for production due not requiring any artisan skills to making them (excepting custom designs and top end frames designed specifically to order).
Like much professional equipment, the frames are marketed to the general public as subtle means of nrainwashing people into thinking it will being into the same category of performance as the pros (e.g. buy the same golf club that the Masters champion uses and you to will be shooting under par from the pro tees). People's minds are frail and easily swayed by psychology into getting something they never could utilize as initially designed
Ride Fast, Be Safe!
Howard
I believe the chips that you see are paint chips. Carbon fiber does not chip, it will, however, completely "explode"
Carbon fiber's reputation for being "fragile" is a bit of a paradox. In terms of absolute structural integrity and longevity, it is actually one of the most durable materials used in bicycle manufacturing. However, it behaves very differently from metals when pushed past its limits.
It's not that fragile-but!
First it is not reinforced plastic! Bad analogy. it is nearly four times as strong as aluminum. The "fragility" label usually stems from two specific mechanical behaviors:
Impact Sensitivity, CFRP is sensitive to concentrated impact damage.
Brittle Failure, Unlike steel or aluminum, which bend or "yield" before they break, carbon fiber has a low strain-to-failure rate. It remains perfectly stiff until it reaches its breaking point, at which it fails catastrophically (snapping rather than bending)
Fatigue Life, On the flip side, carbon fiber has an almost infinite fatigue life. Unlike aluminum, which eventually weakens and cracks after millions of vibration cycles, a properly maintained carbon frame will essentially never "wear out" from normal wear
Mechanical properties of the "T" rating!
The properties of carbon fiber depend heavily on the "tow" (the number of filaments) and the precursor used—most commonly Polyacrylonitrile (PAN).
| Grade | Tensile Strength (\text{MPa}) | Tensile Modulus (\text{GPa}) | Density (\text{g/cm}^3) |
| **Standard (T300)** | ~3,530 | ~230 | 1.76 |
| **Intermediate (T800S)** | ~5,880 | ~294 | 1.80 |
| **High Modulus (T1000G)** | ~6,370 | ~294 | 1.80 |
| **Ultra High (T1100G)** | ~7,000 | ~324 | 1.84 |
*Source: Adapted from Toray specifications and recent composite research (Sayam et al., 2022).*
For comparison, a typical aluminum alloy (6061-T6) has a tensile strength of roughly 310\text{ MPa} and a density of 2.70\text{ g/cm}^3. Carbon fiber provides significantly more strength at roughly **60% of the weight**.
A little technical but you can see the value in the strength.
Two Wheels
Stay Safe
Robert
"SPINMAN"
Great reply, Spinman! Very well said, lol... Wink
Carbon fiber is also used in modern boat hulls, it's MUCH LIGHTER & STRONGER than fiberglass! It's even used in modern surfboards, and those boards are HELLER EXPENSIVE, lol. My best friend Tommy (aka "T-Bone"---his 'handle' while riding shotgun in the big truck on a free vacation) and his family owned & operated the first & oldest surf shop in Coronado for three decades or more, and he clued me in to those carbon fiber boards, letting me check one out and compare it to standard glass boards! Thing was light as a feather, no lie... Confused
Those carbon fiber bikes I saw recently in the 'Tour of the Gila' were FAST, I can tell ya that much, lol. Goldurned things went past me like friggin' METEORS!!! Angel
Cue the Monty Python line: "And now for something completely different!" Big Grin
"GARCON!!! ANOTHER ALCOHOLIC BEVERAGE, SIL VOUS PLAIT!!!" Cool
BWAHAHAHAHAHAHA!!! CHEERS!!! Smile
Sidewinder in Silver City, New Mexico... Rolleyes
"Nothing ventured, nothing gained..."
But the truth really is, they are mostly plastic resin with embedded carbon fibers. The other truth about CF bikes is the fact they are highly over rated and obscenely expensive, because they are the "in" thing right now.
(05-06-2026, 10:29 AM)rydabent Wrote:  But the truth really is, they are mostly plastic resin with embedded carbon fibers. The other truth about CF bikes is the fact they are highly over rated and obscenely expensive, because they are the "in" thing right now.
But of course @NaLya , the actual truth is that CF frames are mostly fiber; not resin. Again, someone speaks without the knowledge required and without doing research in order to provide an educated answer. The frames are in general overpriced (all bike stuff is now and has been for decades, but the CF frames in general are not obscenely overpriced. Even top level Ti and steel frames are not cheap (just order a steel frame from any reputable builder and you will know the truth). And of course they have been the ""in" thing" for over 25 years in the amateur ranks and over 30 years in the pro ranks so nothing new there.
So; CF frames are not fragile, not plastic, and people buy them quite often due to marketing hype (it's what the pros ride), and sales pressure by retailers while others are buying them as informed consumers who want the more efficient tool that they are whether using them in competition, training, recreation etc.
Ride Fast, Be Safe!
Howard
hello every one
With new tires, a Wright Bros 125 year old steel bike would be just fine for riding. Lets see in the future if a 125 year old CF bike is still rideable. I bet not.
As a big rider, 230, I have snapped 2 different alum frames on mountain road climbs. One was all aluminum, the other partial aluminum carbon mix that snapped at the aluminum section. Each frame after 13,000 miles strangely enough. Frames were Lemon but made at the time by Trek. The latter was a Lemond Chambery, sweetest ride I've had, too bad it snapped.
After reading all the paranoid hype on cycling forums over the years, I read that carbon would blow up under a Clydes weight. I have a full carbon Madone and happy to report after 30,000 mile, not one single issue with the frame or fork.
My faith is leaning towards carbon nowadays.
FTR, I have pics of my buddies STEEL DeRosa, not a cheap bike back in 2005 (?) that snapped at the seat tube/BB area. Everything and anything can break. I would say he didn't have more than 10,000 on it. Broke right at the BB lug.
(05-05-2026, 04:30 PM)SPINMAN Wrote:  I believe the chips that you see are paint chips. Carbon fiber does not chip, it will, however, completely "explode"
While the carbon fibers may have a long life, it is the plastic risen the quickly ages as all plastics go. The older they are, the more brittle they ar.
Carbon fiber bike frames are 40% plastic (resin) by weight. Plastic ages and get brittle the older it gets.
(05-18-2026, 10:17 AM)rydabent Wrote:  Carbon fiber bike frames are 40% plastic (resin) by weight. Plastic ages and get brittle the older it gets.
You really should read your own statements because you are contradicting yourself, and you are going to confuse people who might assume you know what you are talking about.
Here is your previous comment in this thread: "...they are mostly plastic resin with embedded carbon fibers."
Now you state that the frames are only 40% resin (not plastic!) which clearly contradicts your previous comment wherein a frame would need to be at least more than 50% resin.
An edit to one or the other comment is required! So which is it? Mostly resin, or mostly fiber? And please provide a couple sources (not AI generic bunk) to help those confused to verify your new proclamation and resolve the issue with facts and not supposition.
The best simple answer for this question is, yes.
When comparing a full durability scale of carbon to metal, carbon can get thrashed easily, and doesn't withstand impacts (or many torque forces) like metal does. Poor grade carbon fiber materials also won't be as chemically resistant, and that's a huge red flag. Unless you're an expect with the metrics equipment available, there's no way to really tell the quality of carbon fiber. While the general price of carbon fiber runs so high, it's easy to be tempted to the cheapest option.
In my opinion, carbon fiber is a specialty material, that you will only want to ride on a bike if it's from an absolutely reputable dealer (with the industry power and legal deterrence to ensure quality); or for a specialty one-night-only type of event.
People out there get lucky with affordable parts that hold up general use. But there's a higher level of care involved as well. If you're a clumsy person like myself, and prone to silly mistakes, you will run through the durability of carbon fiber much easier than metal. This is most often where you see issues like the chips and cracks. They are the silly mistakes of people trying to use a high care, specialty material as a daily driver.
Otherwise, carbon fiber can be incredibly strong, and its specialty properties for aerodynamics, weight, chemical resistance, rigidity, and vibration absorption can only be rivaled by other high quality specialty materials (such as perfect grade titanium).
(06-22-2026, 09:45 AM)ReapThaWhirlwind Wrote:  The best simple answer for this question is, yes.
The answer, as another stated, is no.
The author asked "Are they all that fragile?" No they are not. Is was not a specific question in comparison to any other material (unless I missed something).
If carbon fiber is so "simply" considered "fragile", than why is it used efficiently and successfully in various products (not just bike frames; aerospace, et al.) and at all levels of usage (from layman to professional)?
If carbon fiber was as bad as those in this thread make it sound then it would never have evolved into what is today or be used in such a vast manner.
The truth be known, probably those defending CF bikes probably have money in the game. At the prices they sell for, there is big money in them.
#17
Awesome reply @SPINMAN ! Great read. One day, when I can afford a carbon fibre frame, I'll know what I'm getting into Smile
Gday @eastonrex Welcome here and this topic will give you a great idea how fantastic and informative this forum is
#18
I would far far rather have a titanium frame bike. The metal doesnt rust, and will last nearly forever.
#19
the age old material question is alive here again, if I may I think the matter at hand isn't durability nowadays as modern carbon is super good, I think the real question everyone should be asking is if it would cool parked next to the beautiful vintage bike that @Jesper will bring along
#20
Again CF is not the wonder material that some think it is. The CF tail broke off of 2 and maybe 3 French Airbus airplanes.
36,393
02-05-2021, 11:20 PM
Last Post: Antoniioo77
13,553
10-19-2011, 08:01 PM
Last Post: bob18dnld
Yesterday 05:38 PM
Yesterday 02:10 AM
Hardtail as only bike?
07-12-2026 05:23 PM
Spoke Count Preference
07-12-2026 09:17 AM
07-12-2026 03:34 AM
07-12-2026 02:20 AM
New around here
07-11-2026 10:53 AM
Favorite MTB brand?
07-10-2026 03:16 AM
07-10-2026 03:13 AM
07-09-2026 02:45 PM
no avatar 4. ReapThaWhirlwind
no avatar 5. Mr. Beanz
