Velotric Nomad battery - does anyone else have this on yours? Supposed to or no? [Solved]
Hi all! Anyone with a Velotric Nomad - does your battery have a little glob of what looks and feels like petroleum jelly on one of the two metal tabs just beside of the round connection (see attached two pics)?
I'm having intermittent problems with the motor not coming on, and trying to narrow down possible reasons...is this supposed to be on the battery, or is this something I need to wipe off?
Thanks for any help!!
(07-17-2025, 09:10 PM)Nomad Doug Wrote:  Hi all! Anyone with a Velotric Nomad - does your battery have a little glob of what looks and feels like petroleum jelly on one of the two metal tabs just beside of the round connection (see attached two pics)?
Probably a dielectric grease like silicone, and common on electrical connections exposed to moisture. Helps keep water out and protect from corrosion, etc.; but it is nonconductive. The connection should be tight enough that the grease does not interfere with the electrical circuit. If the connector seems loose then it might be part of the problem (can be fixed if experienced; do not mess with it if under warranty!).
I would spread the grease around any rubber type seal, but keep it off of the pins and receptacles and check operation. Check all wiring for damage, all connections properly made.
Contact the dealer if under warranty now!
Ride Fast, Be Safe!
Howard
Thanks so much!!
What size bike should I get?
Yesterday 05:14 PM
Yesterday 05:09 PM
Call of nature while riding?
Yesterday 05:07 PM
Are carbon frames fragile?
Yesterday 09:03 AM
Yesterday 04:06 AM
Yesterday 03:52 AM
How new adventures begin..
08-01-2026 08:05 AM
Bells as anti-theft devices
07-31-2026 10:49 PM
Beautiful bikes
07-31-2026 10:35 PM
07-31-2026 10:26 PM
no avatar 2. Mr. Beanz
no avatar 4. rydabent
