New: Take Part in the May's Giveaway: Win the LIVALL PikaBoost 2 E-bike Conversion Kit
Replacing BB
Her I have a shimano BB - UN52 68 BC 1.37 x 24
The frame is threaded. I was just wondering if I have too stick with square taperd or can I upgrade ? Also what are they key numbers in that description for size etc. ?
Thanks
[Image: IMG_0062_zpsurhzcne2.jpg]
[Image: IMG_0060_zpsgruakmoe.jpg]
You don't have to stick with square tapered. But whatever you go to has to match your crankset.
The key measurements are basically the width of your BB shell (yours is 68mm) and the length of the spindle. You can measure your existing spindle, but you may need a different length if you change crank sets. Spindle length is mostly determined by the crank, though occasionally you have to make adjustments depending on frame design.
Think a little about what you want to achieve by "upgrading". It can help performance a lot in some cases. But you can also spend a lot of money upgrading BB and cranks without achieving much of anything.
(10-12-2015, 01:20 PM)DaveM Wrote:  You don't have to stick with square tapered. But whatever you go to has to match your crankset.
I think will stick with square tapered as it will just be a commuter. I was also considering changing to single speed at the front and keep original cranks just put single cog on and shorten spindle and 5 speed at rear.
Though if I was too keep the bike for myself I would like to upgrade BB for wheelies Big Grin
Why do you want to replace your UN52?  Unless the bearings are rough and gravely, you are not going to have any improvement.
On my PDG, I thought that there was a BB issue - I took it out, inspected it, and put it back in; it turned out that it was not properly torqued.....  It was the original 1992 vintage UN70.  On a bike that had spent a lot of time out side.
(10-18-2015, 12:07 AM)nfmisso Wrote:  Why do you want to replace your UN52?  Unless the bearings are rough and gravely, you are not going to have any improvement.
The bearing are very rough and Im also looking to change the front from 3 speed to 1 speed, so will need to also change spindle.
POLL: Are non-recumbent riders looking a...
Today 09:28 AM
Yesterday 10:13 AM
What was your first bicycle?
Yesterday 04:45 AM
Is anyone riding with music?
Yesterday 04:32 AM
Great Giro
Yesterday 04:18 AM
What are the best pitch black dark night...
Yesterday 01:11 AM
The great thing about trikes
06-05-2025 12:06 PM
Biking with helmet laws
06-04-2025 10:23 AM
"There's been better times
06-03-2025 09:10 PM
06-02-2025 06:22 PM
no avatar 1. Criminal
no avatar 2. rydabent
no avatar 4. Flowrider
