Installing vintage crank arm
I was wondering if anybody knows how to install a 1980's model Raleigh crank arm. It fell off of my friends bike while he was riding. The square bolt is still attached to the bottom bracket. Any help is appreciated.
[attachment=4272]
if it fell off, it probably has been loose for a long time and is damaged beyond useable.
That said; unscrew the round cap (a coin works as a screw driver); underneath you will find a loose nut or bolt. Put the crank back on the bottom bracket (BB) axle, re-install the nut or bolt (usually takes a 14mm socket), tighten until the crank is fully seated (no wobble).
If there is any wobble, a new crank is required.
Awsome thanks that helps a lot. If a new crank is needed, what style/size crank would i look for.
(06-27-2013, 06:54 PM)jrippah Wrote:  .... If a new crank is needed, what style/size crank would i look for.
one the same length, for the same side of the bike, same interface to the BB.
For example:
http://www.amazon.com/XLC-Alloy-Crank-Arm-Diamond/dp/B005YO157O/
is 170mm long, for the left side, for a square taper BB.
Note: some cranks for square taper have diamond holes, and some have square; the have to match on both sides of the bike.
Hello from NW Ohio
08-22-2026 10:27 PM
I Tried Riding Like the Pros
08-22-2026 07:10 PM
Shimano RevoShift upgrade
08-22-2026 06:14 PM
08-22-2026 06:12 PM
08-22-2026 04:34 PM
Philodo H8 5000W
08-22-2026 04:28 PM
08-22-2026 04:16 PM
08-22-2026 04:13 PM
08-22-2026 01:55 AM
08-22-2026 01:52 AM
no avatar 4. Mr. Beanz
