Pedal Slip
Hi i have just bought a bike (saracen bullet 6061 alli frame) and have taken it out for the first time and i appear to be getting what id call pedal slip, when i pedal along without much force then its ok, when i exert downward pressure or change up to anything over 5th in middle range (21spd) this happens the bike isn't new but second hand and supposedly not ridden although i recon its had some use but not much, i have tinkered with the gears front and back as they weren't working through the whole range the chain could be a little slack but i'm unsure, the crank is raceface and gearing is shimano deore.
Also if anyone knows anything about this bike at all id appreciate it as i cant find any info on it at all...
thanks jon...
[attachment=94]
[attachment=95]
Initial thought would be worn cogs at the back, especially when exerting pressure?
Measure the chain as per this:-<br />
http://bikeride.com/chain-wear/
If the chain is worn then possibly the cogs are as well.<br />
The other possible is the freewheel ratchet slipping.
P.S. Just a couple of notes.<br />
a) The saddle should not be tilted back as per the photo.<br />
That angle may cause personel problems? It should be level.<br />
b) If you put a drinks bottle in that rack then it's going to get covered in c##p or worse.<br />
Get a bottle with a cover just in case, or find another place for it.
thanks 4 yr help
5,055
11-18-2022, 10:37 AM
Last Post: SPINMAN
10,757
11-29-2013, 12:33 PM
11,169
10-27-2009, 03:20 PM
Last Post: cyclerUK
18,643
07-11-2009, 04:16 PM
Last Post: DaveM
