Time to change rim?
Question to v-brake rim users: how do you tell that it's time to change a rim?
I noticed that my rear rim has become somewhat ineffective in recent days. I readjusted my not so old brake pads but no use. The brake lever is not hitting the grips. The bike is like 10 years old, although I used it roughly 5 years. Perhaps the brake-surface has worn-off for good.
Any thoughts on that?
Try to sand a bit your brake pads... They might be glazed... Is your rims alloys?? Carbon??
If the break pads are older than 5 or so years you should definitely replace them. They usually have a wear indicator (deep grooves), if those are gone: definitely replace (reminds me: need to check on my cross bike soon). Rims also have a wear indicator (though I have not yet seen a rim that had been worn down to the indicator), also check this.
There are several companies offering different types of brake pads, I personally like the salmon-coloured ones by KoolStop for wet weather (though brake pad selection also depends on the rim material).
Very few rims have a specific "brake surface" that can wear off. The breaking surface on the rim is worn out when the metal has worn thin enough that there is a risk of the metal cracking/breaking. It's certainly possible you are at this point after 5 years of riding though that really depends on a lot of factors.
But poor braking performance is generally due to old brake pads, poor brake set up, splitting cables/housing, etc.
(07-27-2011, 09:20 AM)bobtravers Wrote:  Try to sand a bit your brake pads... They might be glazed... Is your rims alloys?? Carbon??
Definitely not carbon. They might be alloy.
They are called "Grand Rock".
(07-27-2011, 10:23 AM)Joe_W Wrote:  If the break pads are older than 5 or so years you should definitely replace them. They usually have a wear indicator (deep grooves), if those are gone: definitely replace (reminds me: need to check on my cross bike soon). Rims also have a wear indicator (though I have not yet seen a rim that had been worn down to the indicator), also check this.
How does this "wear indicator" look like? Do you have any pics?
I doubt very much you wore out a rim. Never seen that happen. But than I am not a pro racer.
No idea what is selling in Russia. Here in USA with parts and labor being expensive its usually cost effective and easier to just buy a new wheel. Unless yours is very special.
Sounds more like an adjustment issue. The front does more braking anyway. Something like 70/30.
Your brake lever at the handlebars should not hit the grips if it does you need to tighten cable.
Look at the post below , the notches/grooves in the pads are the wear indicators, I usually change pads when they wear about 1/2 way or so. If you still see lots of groves its OK.
http://www.bikestoreguys.com/product_list/57204.100753.496.100634.0/Brake_Parts_%26amp%3B_Shoes?gclid=CNyH6KikoqoCFcoc6wodMSFNXA
Sorry, I just asked the wrong question. I know what a wear indicator is (on brake pads).
I am told that there is some sort of wear indicator on a rim.
Here's some info on that: http://www.bikegallery.com/blog/2009/check-your-brake-pads-and-rims/
Here's a pic with a worn out rim: http://www.bikegallery.com/blog/wp-content/uploads/2009/03/rim-wear1.jpg
20,879
11-06-2014, 08:59 AM
Last Post: JanJ
11,989
10-20-2014, 04:52 PM
Last Post: DaveM
11,042
05-23-2013, 01:45 PM
Last Post: DaveM
8,650
01-13-2012, 10:06 AM
Last Post: Bill
11,445
03-28-2011, 11:52 PM
Last Post: Bill
