How to improve your braking (GMBN's Guide to Braking)
Came across this and thought I'd share it. Guess it's mountain biking specific.
It's a YouTube video called "How To Improve Your Braking | GMBN's Guide To One Finger Braking"
From my experience, one finger doesn't feel safe, and I'm comfortable with two fingers.
Be interested in what others think.
https://youtu.be/ro9aKuxlhoA?si=6DycKYfh9dFPg2a1
The video is helpful, but I believe it applies to hydraulic brakes only. Not sure if mechanical disc brakes are that “sensitive” or " powerful"..
I’m glad I don’t have too sensitive/powerful hydraulics—otherwise, I’d probably go over handle often. :-(
One thing I tell myself: don’t brake hard, especially when I feel like I’m about to fall. Usually, it’s just fear. If I let the bike handle it, it’s far more stable and capable than I give it credit for..
(08-28-2025, 09:51 PM)Flowrider Wrote:  Came across this and thought I'd share it. Guess it's mountain biking specific.
The other technical advice that they've talked about is braking 70/30%
They say we should rear brake 70% and front brake 30%, with the rear brake engaged first, a few seconds ahead of the front.
This is obviously a skill to be perfected and depends on the terrain you're riding. And for me, off-road
Thanks, @Flowrider for that 70/30 reminder.
Practice truly makes us better. I can’t recall if it was you, @enkei, or another rider on BikeRide who told me to enjoy the moment instead of fearing the worst.
I try to follow that advice, especially with braking—not grabbing one brake too hard, but using both and NOT braking hard, especially the front brake (for me left brake)..
I wonder if we can adjust brakes such that even if we apply both brakes equally, the front will do only 30% job while the rear will do most of the job...
(09-01-2025, 02:54 AM)Flowrider Wrote:  The other technical advice that they've talked about is braking 70/30%
Yea, that reminds me of a quote from Mark Twain: "I've had a lot of worries in my life, most of which never happened".
Enjoy! You're doing something that the majority will never do and wish that they did.
When you look back on your life, a wonderful smile will light up your face. Smile
(09-01-2025, 09:04 AM)GirishH Wrote:  Thanks, @Flowrider for that 70/30 reminder.
I can't remember if I told you that. LOL, I should be telling myself that more.
Where did you come across that advice? It doesn't sound right to me, but I'm willing to learn from experts. It's normally 70:30 front/rear.
I always lead with the rear brake, shifting my weight aft as needed/possible, but use more front brake than rear, unless maybe I'm trying to break the rear end loose for some reason. Even on low-grip surfaces, the front end is generally going to be more heavily loaded than the rear, so it can handle more braking. Obviously, locking the front poses greater risk than locking the rear, hence the need for skill/experience.
Riding a motorcycle, I once came downhill into a T-junction on a cold, wet London evening (a cold and wet London? yes, it happens). As I turned right through the traffic light, I had to traverse the crown of the road, which was a mix of asphalt and embedded gravel, with yellow painted lines across it (the UK's "do not block this junction" warning). The straw that almost broke this camel's back was the slick metal manhole cover...
As the front tire hit the manhole cover (virtually impossible to see in the dark and rain, on the wrong side of the crown of the road until you were already heading for it), I felt the almost imperceptible signs of the front tire starting to lose its grip on the Earth's surface. That was problem number 1.
Problem number 2 was the steel railing that had been installed along the narrow concrete divider (between the two traffic flows) to stop pedestrians stupidly running across the road. In this tiny fraction of my life, my brain's basic understanding of physics informed me that A. I had very little runout room left and B. If I hit that rating, it would hurt. Probably a lot.
Obviously, applying the brakes wasn't a good option at this point. Luckily, I was able to open the steering angle ever so slightly, and the tire regained its purchase on the planet, allowing me to continue on my merry way home and, eventually, share this heartwarming tale with you here.
Can't find it off the bat but here's a great vid on how to improve braking and riding skills from GMBN
https://youtu.be/5Z7-cV6XoXc?si=WI2oP8EzUwas2Znn
these are pretty hard concepts to write about and something you really have to feel while trying out in your local trails, I use the rear brake to modulate my speed and the front only to fully stop, its super hard to explain to someone how to brake to go faster if that makes any sense haha you will feel this as your skills progress that braking at certain points or modulating your speed will actually make you clear a turn faster than just sending it, pretty sure I saw a mob skills video explain this during the pandemic but sadly I can't find it anymore haha
Yeah, agree it's pretty difficult to write about. For me, it's just putting it out there so people become aware of the skill and hopefully try it and find something that works for them. Because I believe it is an invaluable skill that will improve your riding and, therefore, your enjoyment of riding. I'm talking mountain biking here. It may be used in road biking, but I don't know.
Today 11:08 AM
Today 11:02 AM
Today 04:03 AM
