Rear Gear Slips
Hi folks I am new to this when I select the 4th gear at the rear of the bike, the bike keeps that gear for a 1/4 of a turn before it goes into 5th gear by its self, How do I stop this doing this? Please help
Cheers
Peter
I'm not sure if this is right, but maybe the gear cable is a bit loose?<br />
Hope this helps!
I agree with Lawrence, it's probably the cable tension. Check <a href="http://bikeride.com/adjust-rear-derailleur/">this video</a> at about 3:00.
Thanks for the advice I have another problem now, the bikes going back to the shop as the chain snapped while I was cycling home last night. Thanks for the help again
Peter
I have had this chain slipping problem on my recumbent SWB. I broke the chain once and have had slipping which gets progressively worse and noticed that when it begins to slip I have a link coming apart. I have a KMC Z9000 super narrow chain which seems to be problematic. Now if it slips, I check the chain and use my chain tool to repair the link. I just got a new chain and will put it on the bent and see if it stays together and use the other as a backup. I would prefer a little more stability with my chain.
idahomtman,
You might check out these reviews on the Z9000 chain ...
http://www.mtbr.com/cat/drivetrain/Chain/kmc/z9000/PRD_360249_110crx.aspx
Thanks artcat2. I had read those reviews... after purchasing my bent with the Z9000. Go figure. Anyway I replaced it yesterday with a SRAM and so far so good.
5,105
04-27-2020, 03:24 PM
20,794
06-02-2014, 04:41 PM
Last Post: BingoBilly
27,636
10-31-2012, 11:43 AM
Last Post: lupystar
15,399
10-21-2012, 04:23 AM
Last Post: 1FJEF
15,406
12-30-2010, 11:29 AM
Last Post: sidmarx
