wheel possibilities
My front fork INNER measurement, from the top inner surface, at the arch, to the centre of where the axel sits....is 12 inches.
The inner fork Width is 4.75 inches.
The Dia-Comp BRS 200 single pivot brake, without pads, is 59 mm Max and 39 mm Min.
The verticle distance from the brake attachment bolt centre, to the middle of the pads (middle of wheel rim) is 1.75 inches.
What sizes of wheel might fit here?
Thanks.
This is in BMX I just noticed.
Most BMX are 20".
If it was 24" it would be very obvious.
Here's a comparison.
Attached Files Image(s)
(06-11-2023, 01:03 AM)Sound22Card Wrote:  My front fork INNER measurement, from the top inner surface, at the arch, to the centre of where the axel sits....is 12 inches.
Thanks.
Based on your measurements, a standard 26-inch wheel is the most likely fit. The 12-inch inner height is the key dimension that points to this size. You should also verify the wheel's axle type (e.g., QR, thru-axle) matches your fork's dropouts for a proper fit.
11-05-2026 08:22 PM
11-05-2026 08:15 PM
11-04-2026 05:51 AM
