Replace disc brake pads [Solved]
First time doing this, I have to be 100% confident. Are there any risks and potential failures that have to be considered before switching the disc brake pads? I just bought the same pads I have had before, Shimano B01S resin. Will switchem th tomorrow hopefully. Nothing much can go wrong, right?
(09-09-2019, 06:53 PM)bibimbap Wrote:  First time doing this, I have to be 100% confident. Are there any risks and potential failures that have to be considered before switching the disc brake pads? I just bought the same pads I have had before, Shimano B01S resin. Will switchem th tomorrow hopefully. Nothing much can go wrong, right?
first of all, you have to make sure that pads are actually worn out and need replacement. sometimes the squeeky noise is caused by other factors, such as rotor. overall it's an easy process, don't play with the brake lever while you are doing the swap - just in and out.
There is an adjuster hex screw on one side of the caliper (mine is closest to the spokes. If your new pads are tight and binding, just undo the adjuster screw. (Mine clicks.) This is used as the pads wear. The main adjustment is done from the brake lever end. It's actually quite easy.
Thank you both for the heads up. I went for it now and seems like everything is OK Smile
(09-13-2019, 04:27 PM)bibimbap Wrote:  Thank you both for the heads up. I went for it now and seems like everything is OK Smile
Good on ya! I now pronounce you 'Master Mechanic.'
Santini fluted frame
Today 01:52 AM
2010 Specialized Hardrock
03-26-2024 09:16 PM
03-25-2024 07:05 PM
03-24-2024 08:52 PM
Trek domane tyre
03-24-2024 05:48 PM
03-24-2024 05:32 PM
Cup & Cone — Simple & Durable or PITA & ...
03-24-2024 04:53 PM
Falling back
03-24-2024 04:45 PM
Derailluer Hanger Alignment Tool
03-24-2024 02:51 PM
Chain sits on top of chainring when shif...
03-24-2024 02:41 PM
no avatar 1. Painkiller
