26" to 700C conversion.
Hi,
I am converting a MTB with 26" wheels to 700c. I live in the UK and do not go off road, but would like a bike to ride on canal tow paths (some of which can be a "little rough". All is OK, have swooped out the front forks to a rigid type (with the correct bosses for mounting a V brake onto a 700c wheel) - but....i would prefer too fit V brakes on the rear, and the bosses are in the wrong place. I know that Mavic used to do a converter, but cannot find one anywhere. Has anyone else done this? and what did you do?
Many thanks in advance.
Kevan
Hi Kevan;
Take a look at these:
http://www.ratrodbikes.com/forum/index.php?threads/modern-v-brakes-on-a-vintage-frame.33168/#post-323461
https://www.biketrailershop.com/xtracycle-26-to-700c-brake-post-conversion-adapter-p-1600.html
https://leagueofbikepolo.com/forum/general/2012/10/19/diy-v-brake-adapter-for-center-mount-frames
I am using these on a 559 to 590 conversion:
http://elevnracing.com/products/brake-adaptators/
they only provide 16mm, not enough for 559 to 622; which is 31.5mm radial difference.
I would probably put a caliper brake on instead, it would be easier.
Hi Nigel,
Many thanks for the great information. Will probably go with calipers as you suggested - will still need standard drop on front and deeper drop on rear.
Although... have found the Freeradical adapter plate from a UK supplier (http://practicalcycles.com/products/188742--xtracycle-700c-v-brake-adaptor.aspx) even if they are taking the piss when it comes to price.
I have a spare deep drop Miche caliper, think I will try that first then make a final decision.
Again, many thanks for the quick and useful reply.
Cheers,
Kevan
Hi Kevan;
To be clearer than I was, I would stick with the V-brake on the front, and caliper on the back. You will need appropriate levers for each end. I have done a couple bikes with mismatched brakes, work great. One was the Black GT, it has a V-brake on the front and a U-brake on the back. OEM spec was a cantilever on the front and a U-brake on the back.
Cheers Nigel. Good advice, Many thanks
Kevan
Yesterday 01:39 PM
2010 Specialized Hardrock
Yesterday 05:54 AM
QUINTANA ROO "KILO" 1999
04-22-2024 02:04 PM
04-22-2024 01:35 PM
04-22-2024 01:31 PM
04-22-2024 01:26 PM
04-22-2024 01:12 PM
Fat bikes for ever..
04-22-2024 12:23 PM
Rear hub issue
04-21-2024 09:01 PM
Lectric One
04-17-2024 09:58 PM
no avatar 5. Frankly
